Radiator Shell Lacing
Posted: Wed Aug 26, 2020 10:19 pm
by cntbill
Put on new lacing on my radiator shell but not sure what to do with the two ends, do I just trim it close to the end and just let it hang or wrap it around ?
Thanks,
Bill...
- End 1
- End 2
- End 3
Re: Radiator Shell Lacing
Posted: Thu Aug 27, 2020 12:44 am
by jiminbartow
Trim ends even with the bottom of the shell flange. The purpose of the lacing is to prevent metal to metal contact and the noise that would occur from intense vibration. Jim Patrick
Posted: Thu Aug 27, 2020 1:16 am
by cntbill
OK, then what about putting a spot of silicon on the very bottom to help keep the lacing in place?
Posted: Thu Aug 27, 2020 2:05 am
by Allan
Just cut it of an inch or so from the last hole. It won't go anywhere.
Posted: Thu Aug 27, 2020 9:11 am
by cntbill
Ok, Thanks guys, that is what I'll do. I just wasn't sure what the proper method was.
Posted: Thu Aug 27, 2020 5:43 pm
by DHort
- rad.jpg (30.37 KiB) Viewed 3051 times
The lacing is wax impregnated which made it stiff enough that I just bent the last 2 inches or so and stuck it between the shroud and the radiator. It isn't going anywhere.
Posted: Thu Aug 27, 2020 8:14 pm
by cntbill
Makes sense, Nice headlamp !
Posted: Thu Aug 27, 2020 9:06 pm
by DHort
My car should be all black. A previous owner plated the headlights, shroud, and side lights. 1920 - wanted it to look like a brass car.
Posted: Fri Aug 28, 2020 10:42 am
by Adam
I believe the original lacing wrapped around and tucked between the shroud and the lacing on the loop above it.
Posted: Fri Aug 28, 2020 11:00 am
by DanTreace
Ford Service photos of end of radiator shell lace, just trim the loose end short to hang just inside the shell behind the frame.
Posted: Sat Aug 29, 2020 12:47 am
by cntbill
DHort wrote: ↑Thu Aug 27, 2020 9:06 pm
Wondering about that, but still looks neat....
Adam wrote: ↑Fri Aug 28, 2020 10:42 am
Sounds like a plan....
DanTreace wrote: ↑Fri Aug 28, 2020 11:00 am
Much better photos then the Ford Service book that I have....
Thanks guys! Solves my mystery...
