Flip top jack
Topic author - Posts: 1708
- First Name: Jeff
- Last Name: Humble
- MTFCA Number: 28034
- Board Member Since: 2006
Flip top jack
Was at the Benson Ford Research Center today, found the jack drawings. The pressed steel jack changed to the flip top design in drawing dated August 1925. The part number remained the same. Applicability: "all T chassis".
- Last Name: Morsher
Re: Flip top jack
Thanks Jeff ! Do you remember if the flip part had a hole, or no hole on the side?
- First Name: Jeff
- Last Name: Humble
Re: Flip top jack
I do not remember seeing one there, but I didnt look for one either.
Re: Flip top jack
Thanks , I just stole this from the model A site. They say the “no hole” is model T. It’s nice to know the date now !
- First Name: Bill
- Last Name: Chuplis
Re: Flip top jack
With the suspension being lowered on the 26-27, the date, more or less speaks for itself. The non-flip type is a mystery to me. They look too short for use on a 25 and bit too tall for use on a 26-27.
- Attachments
- 575843_kindlephoto-2003771.jpg (19.29 KiB) Viewed 5442 times
Re: Flip top jack
Here are all that I know of. It would be nice to have aprox dates with them. The model A historians have pinned their jacks down to the month.
- MTFCA Number: 4838
- MTFCI Number: 115
Re: Flip top jack
Info researched by Trent Boggess
On 9/10/24 the pressed steel jack design was adopted.
The car jack is 8-5/8” tall and the base is 4-1/2” across.
The handle was made a separate part and carried the
factory symbol number T-3391-B.
...the old style screw jacks were declared
obsolete on 9/13/24. It appears that the pressed steel
design were the standard issue jacks on the 1925 models.
About a year later on 8/4/25 the design of the jacks was
revised. On both the car and truck jacks a two-inch
extension was added to the top of the jack.
Old style screw jack compared to 1926 style flip top, compressed size on front axle, Improved Car
Old style screw jack compared to 1926 style flip top, extended size on rear axle, Improved Car.
- MTFCI Number: 115
Re: Flip top jack
And that flip top jack is well suited as the 'universal jack' as it can be used with the 'flip' folded over if the front tire is flat on the ground, either style of T's early or late. With the flip over......that jack is the lowest version to fit under the T front axle
- First Name: Bill
Re: Flip top jack
The date for the hole addition in the flip top is probably buried somewhere the Walker Jack Co. files.
It doesn't seem to serve any Ford purpose so it's doubtful they made it a requirement.
- Last Name: Golden
- MTFCA Number: 14294
- MTFCI Number: 13562
Re: Flip top jack
While I learned some time ago that the hole was in the Model A jack, I have never been able to find a reason for that hole.
- First Name: Bill
Re: Flip top jack
Never been able to find the reason they're (MAFCA) so sure the hole was never there prior to the 28 model year either.
- First Name: David
- Last Name: Stroud
- Board Member Since: 2011
Re: Flip top jack
Bill C., the lower suspension on the later cars would have nothing to do with the jacks. Tire size would though. JMHO Dave
1925 mostly original coupe.
- First Name: Bill
Re: Flip top jack
So could raising the front spindles without changing the tire diameter.
From the encyclopedia:
"The “improved” Fords were lower in height than the previous models. This height reduction was accomplished by not only reducing the height of the bodies themselves (except for the Fordor) but also by lowering the frame by a redesign of the front spindles, and a reduction of the crown in the front spring."
