glue or screw?
Mustang1964s
Topic author - Posts: 272
- Last Name: Bourgeois
- * REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
glue or screw?
I am working on the wood in the back seat.
Things are lining up pretty well.
So far all the wood has been pre-drilled and just needed some minor adjustment.
The bottom joint of the rear raisers glued or should the be screwed?
Here is a pic of the joint I am talking about.
- Last Name: Strange
Re: glue or screw?
My personal opinion, I would use screws. Over time there is bound to be some relative movement between the parts, which will either cause the glue to fail or break the wood near the joint.
Mustang1964s
Re: glue or screw?
Thank you,
That is what I was thinking. Just needed verification.
halftracknut
- First Name: randy
- Last Name: lee
- * REQUIRED* Type and Year of Model Ts owned: 1926 pickup
Re: glue or screw?
I use 3/16 flat head bolts and lock washer and nuts
HalSched
- First Name: Hal
- Last Name: Schedler
- * REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
Re: glue or screw?
Do both...Glue and Screw
- Last Name: Patrick
Re: glue or screw?
For authenticity, Use antique brass slot headed wood screws. They did not make Phillips head wood screws back then. If you are unable to fine old slot head wood screws, modern slot head screws can be made to look old. Modern screws have a very shallow slot and a flat head with circular machining grooves. You can make the new screws look old by carefully deepening the slot with a dremel tool equipped with a thin metal cutting grinding disc and removing the machining marks with sandpaper. Jim Patrick.
dykker5502
- First Name: Michael
- Last Name: Deichmann
Re: glue or screw?
Not a good idea. The glue will still risk to break the wood as the body is ment to flex with the frame.
Ford Model T 1914 Touring
Ken Buhler
- First Name: Ken
- Last Name: Buhler
- Board Member Since: 2012
Re: glue or screw?
Right on Michael, Every thing about these cars is about flexibility. Perhaps think: Yoga, or Tai chi.
Work honestly
Stay true to your word
Get the job done right
John Codman
- Last Name: Codman
Re: glue or screw?
No Model T ever had a Phillips head screw from the factory. The Phillips screw was patented in 1932.
Mustang1964s
Re: glue or screw?
I know. They are going to be hidden.
The screws that are visible have been special ordered.
Ford almost put square head screws in his cars.
