Free Start need Help
Topic author - Posts: 11
- First Name: Michael
- Last Name: Archer
- * REQUIRED* Type and Year of Model Ts owned: 1922 Roadsters
- MTFCA Number: 30647
My buddy and I rebuilt the engine on my 22 roadster. It seems to have great power and is running perfect. The only issue I have is too many free starts- it literally happens almost every time. Has anyone else had this problem and any suggestions on how to fix it is much appreciated.
Mike
Mike
- First Name: Rich
- Last Name: Bingham
Re: Free Start need Help
!!? How, exactly, is this a problem ?? Wish mine would do that. I only get about 10%.
"Get a horse !"
Nothing wrong with that. Saves battery, or arm.
- First Name: Erik
- Last Name: Johnson
Let your motor idle down before turning off the ignition.
- First Name: Peter
- Last Name: Claverie
If you're serious, and want to stop the free starts, simply turn the key to MAG instead of BATT.
I'm told this requires pulling the spark lever down a couple of notches, but I have no experience here.
- Last Name: Codman
I agree with Rich Bingham. I wish that I had your problem. I have had three free starts in the last seven years.
- MTFCA Number: 16175
- MTFCI Number: 14758
Peter has it right. No free starts when you start on MAG. Of course without using the battery you have to pull the crank fast enough to make sufficient juice for the coils. And yes, the spark lever should be down a few notches.
The problem will go away if you get the starter motor engaged before you switch the ignition on.
- First Name: Andre
- Last Name: Valkenaers
- MTFCA Number: 23792
- MTFCI Number: 19330
What is wrong with a free start?
My three T make them on about 9/10 of the starts.
Andre
Belgium
Andre
Belgium
- First Name: Don
- Last Name: Allen
- MTFCA Number: 50001
My guess is that you’re switching the ignition off with the engine at a high rpm.
I can make my car give a free start most of the time by doing that. If I idle it down before switching it off, it hardly ever free starts. I suppose it has to do with how much un-burned fuel vapor there is in the cylinder.
1924 Touring
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
I close throttle and timing before I turn off switch. I get lots of free starts with the 26. Even after setting for a week. Never a free start on mag.
- First Name: Greg
- Last Name: Popove
I wouldn't complain.
- First Name: Robert
- Last Name: Hester
- * REQUIRED* Type and Year of Model Ts owned: 26 touring, 27 touring, 22 TT
- MTFCA Number: 26459
- MTFCI Number: 20813
He's just bragging.
