Free Start need Help
Posted: Mon Sep 07, 2020 3:30 pm
by MichaelA
My buddy and I rebuilt the engine on my 22 roadster. It seems to have great power and is running perfect. The only issue I have is too many free starts- it literally happens almost every time. Has anyone else had this problem and any suggestions on how to fix it is much appreciated.
Mike
Re: Free Start need Help
Posted: Mon Sep 07, 2020 3:32 pm
by Rich Bingham
!!? How, exactly, is this a problem ?? Wish mine would do that. I only get about 10%. :lol: :lol:
Posted: Mon Sep 07, 2020 4:33 pm
by Norman Kling
Nothing wrong with that. Saves battery, or arm.
Posted: Mon Sep 07, 2020 4:43 pm
by Erik Johnson
Let your motor idle down before turning off the ignition.
Posted: Mon Sep 07, 2020 4:46 pm
by Peter, Memphis TN
If you're serious, and want to stop the free starts, simply turn the key to MAG instead of BATT.
I'm told this requires pulling the spark lever down a couple of notches, but I have no experience here.
Posted: Mon Sep 07, 2020 5:30 pm
by John Codman
I agree with Rich Bingham. I wish that I had your problem. I have had three free starts in the last seven years.
Posted: Mon Sep 07, 2020 5:35 pm
by Steve Jelf
Peter has it right. No free starts when you start on MAG. Of course without using the battery you have to pull the crank fast enough to make sufficient juice for the coils. And yes, the spark lever should be down a few notches.
Posted: Mon Sep 07, 2020 8:32 pm
by Allan
The problem will go away if you get the starter motor engaged before you switch the ignition on. :)
Posted: Tue Sep 08, 2020 7:11 am
by AndreFordT
What is wrong with a free start?
My three T make them on about 9/10 of the starts.
Andre
Belgium
Posted: Tue Sep 08, 2020 7:21 am
by RustyFords
My guess is that you’re switching the ignition off with the engine at a high rpm.
I can make my car give a free start most of the time by doing that. If I idle it down before switching it off, it hardly ever free starts. I suppose it has to do with how much un-burned fuel vapor there is in the cylinder.
Posted: Tue Sep 08, 2020 8:46 am
by Dallas Landers
I close throttle and timing before I turn off switch. I get lots of free starts with the 26. Even after setting for a week. Never a free start on mag. :D
Posted: Tue Sep 08, 2020 9:32 am
by Fordwright
I wouldn't complain.
Posted: Tue Sep 08, 2020 9:59 am
by tmodeldriver
He's just bragging.
