Routing Distributor wire
Mustang1964s
Last Name: Bourgeois
MTFCA Number: 29784
MTFCI Number: 22970
Post by Mustang1964s » Fri Sep 11, 2020 9:47 am
I am thinking of re-routing the wire to the distributor to match the path of the wiring loom.
Is this going to cause issues with the length of the wire extended?
What gauge of wire should I use?
The coil is up on the firewall on the drivers side.
Mustang1964s
MTFCA Number: 29784
MTFCI Number: 22970
Re: Routing Distributor wire
Post by Mustang1964s » Sat Sep 12, 2020 2:49 pm
I purchased 12 gauge wire to do the run around front and down the side.
The wire on the condenser seems to be very small.
Hope this works.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Sep 12, 2020 6:40 pm
I would seriously consider relocating the coil to the front of the engine, probably to the rh water outlet bolt. I’ll look for a picture of mine.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Sep 12, 2020 6:43 pm
I hope this helps
I hope this helps
First Name: DAVID
Last Name: HJORTNAES
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Sat Sep 12, 2020 10:23 pm
My coil is on the passenger side of the firewall. There is a loop of string hanging from the rod under the hood that all the wires run through. Never a problem.
Mustang1964s
MTFCA Number: 29784
MTFCI Number: 22970
Post by Mustang1964s » Sat Sep 12, 2020 11:06 pm
I really like the idea of relocating to the passenger side.
The only issue might be the heat off of the exhaust manifold.
I will take a look at it tomorrow.
jsaylor
Last Name: Saylor
MTFCA Number: 1695
MTFCI Number: 23870
Post by jsaylor » Sun Sep 13, 2020 2:59 pm
Made a bracket to mount the coil on the water outlet bolt.
coil mount (1).JPG (38.78 KiB) Viewed 248 times
