top bows and sockets
1913Oscar
First Name: Steven
Last Name: Meudt
Post by 1913Oscar » Fri Sep 11, 2020 2:26 pm
Hello, I recently aquired a 1917 Roadster with the front top bow broken off in the socket. what "fasteners" hold the wood bow in the socket and also what is best method to remove the wood ? Thank You
MTFCA Number: 16175
MTFCI Number: 14758
Re: top bows and sockets
Post by Steve Jelf » Fri Sep 11, 2020 3:07 pm
Looking at top sockets here, I see two rivets in each one to hold in the bow. You have to grind off the ends and punch them out.
1913Oscar
First Name: Steven
Last Name: Meudt
Post by 1913Oscar » Fri Sep 11, 2020 10:12 pm
Hi Steve, thank U 4 Your reply...I have examined the socket , I can not find any rivet type fastener on the socket . again..thank U 4 Your reply
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Sat Sep 12, 2020 12:29 am
1917 roadsters and tourings have round top sockets.
After the wood bow is inserted into the socket, there is a single nail that goes through the socket and into the wood bow.
I have posted photos in this thread:
viewtopic.php?f=2&t=11380&p=85110&hilit ... ail#p85110
Note: on the roadster top bows I posted, the nails are on the top or front of the first two sockets and on the bottom or rear of the third socket.
However, on my dad's 1917 touring, the nails are on the outer sides of the sockets.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Sat Sep 12, 2020 10:57 am
What Eric said. The oval wooden bows' ends are tapered to fit tightly into the tapered socket all by themselves, and the tack is intended to be a safety measure.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
"Erik" not Eric. I apologize.
1913Oscar
First Name: Steven
Last Name: Meudt
Post by 1913Oscar » Tue Sep 15, 2020 10:32 pm
Many thank you 2 Mr. Jeff, Mr. Johnson and Mr. Anderson for all Your help...Your knowledge just made my project easier to deal with ! Would anybody happen to have a top bow that would fit on a 1917 roadster ? I am also looking for a complete top assembly to fit a 1913 touring. Thank You
1913Oscar
First Name: Steven
Last Name: Meudt
Post by 1913Oscar » Tue Sep 15, 2020 10:33 pm
sorry..Mr. Jelf...
1913Oscar
First Name: Steven
Last Name: Meudt
Post by 1913Oscar » Tue Sep 15, 2020 10:35 pm
sorry..Mr. Jelf...
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Post by Oldav8tor » Wed Sep 16, 2020 3:06 pm
You've got to forget the "Mr." stuff....those guys will get big heads and be impossible to deal with.
You can buy bent Oak bows from the vendors like Langs and Snyders for a reasonable cost. If you want a laminated bow (more $$) contact Jonathon Anderson <jpautowood@gmail.com>. I bought a complete set of bows for my '17 Touring from Jonathan and they are top quality. You'll need to use a spoke shave and sander to taper the ends to fit the sockets. Jonathan puts a pencil mark on them showing how far they need to go into the socket.
As to getting the old wood out....whatever works. I got a few to come out by taking the socket, turning it upside down and whacking the open end on a board or the like. I had a friend drill a hole in some with a long drill bit then glue a dowel into the hole - pulling it out when it dried. Use your imagination.
One suggestion, after cleaning out the old wood you might want to consider filling the section of the socket below the bow with pourable epoxy. It seals and strengthens the socket. You can drill and tap it for a machine screw to hold the little leather straps with the T head cotter pins.
Good luck!
BTW - which state are you in?
1952 Willys M38a1 Jeep
Post by Allan » Wed Sep 16, 2020 5:43 pm
Often the tack/rivet deforms the socket and raises a pinchpoint into the wood. If you can't budge it I have resorted to the following on some well used sockets. I used a torch to heat socket enough to well char the timber within. Once it has been burnt, it is easier to work them loose and withdraw them. the heat also liberates some of the internal rust in the socket. This is something drastic if you have a nice set of sockets, but if needs be, .....
Hope this helps,
KeithG
First Name: Keith
Last Name: Gumbinger
MTFCA Number: 4661
MTFCI Number: 6866
Post by KeithG » Wed Sep 16, 2020 8:55 pm
Tim, Steven Meudt is in Dodgeville, WI.
Keith
'14 Touring, '26 Roadster Pickup, '27 Fordor, '25 TT C Cab with Express Bed.
1913Oscar
First Name: Steven
Last Name: Meudt
Post by 1913Oscar » Sun Sep 20, 2020 10:13 pm
Thanks Guys...ok i'll drop the "Mr." part HAHA ...i got the sockets cleaned out as You suggested......i plan on doing the "go over" on the bows and top late winter ...i may be getting back to You then when SHTF !! LOL
First Name: DAVID
Last Name: HJORTNAES
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Sun Sep 20, 2020 10:36 pm
Steve
I think everyone here knows Mr Jelf as Steve or Mr Jeff. He is use to being called Mr Jeff.
