timer problems
Posted: Fri Sep 11, 2020 11:46 pm
by Mr man
i took my timer off to clean, and when i put it back on, and all the wires, and tried to start it, it would not start and the carburetor started backfiring. any ideas? its a tiger timer.
thanks,
carson
Re: timer problems
Posted: Sat Sep 12, 2020 12:05 am
My guess would be that you got a wire or two in the wrong place.
Be sure all wires are in the right place.
While you're at it, check the timing: http://dauntlessgeezer.com/DG97.html
Re: timer problems
Posted: Wed Sep 16, 2020 2:33 pm
by MKossor
Did you remove the roller? Some CAM shafts are drilled all the way through allowing the roller to be installed 180 degrees off (i.e. Backwards)
Re: timer problems
Posted: Wed Sep 16, 2020 4:59 pm
by Mr man
yes, it turns out i had the roller backwards!
thanks for the help guys
