13T - Rocky Mountain Brakes and While You're There
Posted: Mon Sep 14, 2020 3:29 am
My 13T doesn't have Rocky Mountain brakes but I plan on buying a set for safety reasons which are enumerated in countless threads on this forum. I also have unknowns with this 13T such as if my grandpa replaced the babbit thrust washers with brass/bronze. I would hope he did because of the extensive tours/jamborees he participated in; however, I ultimately don't know.
If I purchase a Rocky Mountain braking system and I'm going to be back in that area of the T anyway... what all should I knock out while I'm back there? For example:
- Replace thrust washers period? Or only if they're babbit/white metal?
- New gaskets for the differential seem a given
- Are there any other parts along the axle, differential, etc I should consider inspecting/replacing?
Also, some clarification on the critical safety issue of bronze thrust washers. Entering a search of bronze thrust washer into Lang's website returns a result of a brass thrust washer, modern roller bearing thrust washer assembly, etc. A Snyder's search returns a bronze axle thrust washer which looks very different from anything Lang's has. What am I looking for exactly?
I'll start digging into past forum topics on rocky mountains and differentials... but when you're newer, sometimes you don't know what you don't know. Looking for some guidance of "Well, while you're back there" suggestions.
Thank you for your time,
Darin
Darin
