Questions About Painting
BLB27
First Name: bruce
Last Name: brakke
MTFCA Number: 31192
Post by BLB27 » Mon Sep 14, 2020 3:04 pm
I am going paint a 1927 coupe steel spare tire wheel as a trial run before painting the other four wheels. I will get it sandblasted and then prime and paint by spray can. It looks to me that painting the individual spokes by spray is going to be difficult. It also appears to me that by the time I get all the spokes painted that the over spray is going to cause a lot "thick" paint on the rest of the wheel. I am new at painting so any thoughts regarding these two items or any other suggestions about painting wheels will be appreciated.
I am also going to paint the two splash pans that fit on either side of the motor. The paint is appears to be fairly good. There is some rust areas. Should I get them sandblasted (I worry about warping)? If I don't sandblast, should I remove all paint (how?)?
First Name: DAVID
Last Name: HJORTNAES
MTFCA Number: 28762
MTFCI Number: 22402
Re: Questions About Painting
Post by DHort » Mon Sep 14, 2020 3:25 pm
Get the biggest wooden dowel you can find (closet pole). Glue, or attach however you want some wood wedges to hold the wheel upright. Place it between a set of nails on a couple of saw horses and you can spin the wheel as you spray. Do not spray any paint on the inside of the wheel that contacts the hub. Others will come up with other suggestions. Take your pick.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Mon Sep 14, 2020 5:20 pm
I just blasted a pair of engine pans last week. No problem. I used my preferred chassis paint on them (satin black Rustoleum) and baked them at about 180º for a couple of days.
Last Name: Kuehn
MTFCA Number: 28924
Post by John kuehn » Mon Sep 14, 2020 6:09 pm
Curious question.
What did you bake them in. They are pretty good size!
Thanks!
Post by TRDxB2 » Mon Sep 14, 2020 6:17 pm
......... Do not spray any paint on the inside of the wheel that contacts the hub. ......
Why?
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Mon Sep 14, 2020 6:27 pm
I don’t know what you intend to sandblast, but do not blast the wood. If you blast the rims, protect the wood by wrapping the spokes near the rim with thick 3M rubber (not vinyl) tape. Be careful, also, in blasting the dowel ends poking through the rim holes. Dab on some rubber RTV, such as the right Stuff to the dowel ends. The reason for this is to cause the sand to bounce off the wooden portions. Ten years ago, I painted the wooden spoked wheels of my 1926 coupe and they look as good today as they did ten years ago. Using a good 1 1/2” angled sash paint brush, I primed my wooden spokes by hand using Sherwin Williams Oil based exterior primer (old timers know it as A-1 primer) then, it was allowed to dry for at least 4 days to a week (as long as it emanates a strong smell, it is still drying). I painted the primed spokes with Sherwin Williams oil based gloss black enamel. On the steel spoke rim and steel center hub parts, I applied Sherwin Williams red oxide primer by hand using the same brush, then, using the same gloss black enamel, carefully paint the steel parts by hand. If you apply the wood primer to the spokes, then The red oxide primer to the steel, it is much easier to hand paint the entire wheel (primed steel and wooden parts) at the same time, using the gloss black enamel.
These paints are very high quality with lots of pigments that provide the ultimate protection to the wheels, which are very susceptible to water damage from mud puddles and rain. Sherwin Williams also makes a product called “Silver Brite”. A very durable, bright silver paint for painting metal roofs. I apply this with brush to my demountable rims and it is shinier and looks better, longer, than zinc plating or galvanizing. All of these paints Go on thick and level out very smoothly, eliminating all brush marks. Jim Patrick
Post by Allan » Mon Sep 14, 2020 8:37 pm
Frank, the inside of a whire wheel centre and the taper on the axle hub, need to fit closely. They are part of the way the two mount and supply support to the wheel. Otherwise the cracking which often happens at the stud holes would be even more likely. A thick powdercoat will even stop the wheel mounting correctly. I leave the hub un-painted and the wheel just primed to prevent rust.
Hope this helps,
BLB27
First Name: bruce
Last Name: brakke
MTFCA Number: 31192
Post by BLB27 » Mon Sep 14, 2020 8:46 pm
Jim, My wheels are steel not wood.
