Choke hole location in radiator
Topic author - Posts: 271
- First Name: Dick
- Last Name: Cruickshank
I'm in the middle of installing a new radiator as I write this. I saw a recent forum item that described the exact location for drilling the choke hole in the radiator. I tried searching the forum but can not find it. It was only in the last week or so. Any help asap.
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
Re: Choke hole location in radiator
- First Name: Dick
Thanks to all. I took a chance and thought I remembered and you have confirmed my memory. The only thing I couldn't do was use a "punch". I guess if I had the radiator off and could put something behind the area, I could have used a punch of some sort. Used a drill and it worked. Thanks again!!
- First Name: Darren
- Last Name: Wallace
Mine was never drilled for the choke rod and it’s an early Canadian’13. Built in October 1912.
- Attachments
- 3003E68A-2732-4DDB-9AB2-A1AF2D0D754B.jpeg (38.15 KiB) Viewed 1515 times
- First Name: Darin
- Last Name: Hull
- * REQUIRED* Type and Year of Model Ts owned: 1913 Model T
- MTFCA Number: 29699
- MTFCI Number: 25147
- Board Member Since: 2010
I followed the diagram John posted on my recent thread after purchasing a new Brassworks radiator. It was easy and worked perfectly.
