window lift straps
Posted: Sat Sep 19, 2020 4:12 am
by Gene
How do you hook the lift strap to the window on a 1 ton TT truck, or is it hooked some other way?
Re: window lift straps
Posted: Sat Sep 19, 2020 7:48 am
by One390
Gene
Try these threads. I used an old window lift channel and made the rod and mount by cutting, bending and welding a little rod to attach the strap. You have to fool with length so the window is up in the last hole. Wasn’t too bad of a job if I recall. Others can suggest what to use to keep the glass in the channel.
http://www.mtfca.com/discus/messages/11 ... 1287772854
http://www.mtfca.com/discus/messages/29 ... 1204327449
