My name is Patrick i come from germany,my english is not so good.
I have a Model T from 1926/27
The first problem is that my first gear does not work properly, on the straight it goes but as soon as a mountain comes, it no longer makes it, second gear works fine.
I have already renewed the brake bands but they didn't get any better. I forgot to bathe them in oil first.
Now I've bought new cams and I hope that's because I can't think of anything else
Do you still have ideas? Or do you see what is wrong in the pictures?
The second problem is, I found this sheet metal plate in the oil pan, it's from the magnetic disk
the car has been running so far.
do I really need this?
because that would be a bit more work, right?
greetz
thanks patrick
