If you need help logging in, or have question about how something works, use the Support forum located here
Support Forum
- MTFCA Number: 16175
- MTFCI Number: 14758
Post
by Steve Jelf » Tue Sep 22, 2020 12:44 pm
When I took apart my 1923 touring's transmission to replace a busted low drum, I found that one of the triple gears had seized and spun the pin. It wallowed out the hole enough to make the pin wobble quite a bit, so the flywheel is toast. So I went to the barn and picked out a "new" flywheel that looks like it will serve. In reading about installing new pins I read in the Transmission book, As the holes in the cast iron flywheel become slightly enlarged when the steel shafts are withdrawn, it is necessary to use pins which are .003-inch oversize on the section of the shaft that presses into the flywheel. The use of .005 oversize pins requires that both the hole and the pin be measured and the hole reamed for a .002 press fit.
1 Is the reference to both .003 and .005 a misprint or is it about two different pins?
2 Are the new pins not tapered like the originals?
3 If they are tapered, how do you ream the holes with a taper? Or do you?
4 I assume the oversize is in the part of the pin that presses into the hole, and that the part which supports the gear and bushing is the original .675". Is that right?
5 I've seen different tolerances given for the bushings. How much is enough for the gears to operate with no chance of seizing?
Jeepbone1
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
- MTFCA Number: 50618
Post
by Jeepbone1 » Tue Sep 22, 2020 12:49 pm
Give Bob a call over at Bob’s antique auto. He’s the one making the new pins. I just installed a set in my trucks flywheel. Nice machining and they installed very well. The end of the pin is slightly oversized to make up for the wear of driving the old pins out.
Brad
Post
by Allan » Wed Sep 23, 2020 12:34 am
If the bush seized on the pin and it spun in the flywheel, there was not enough clearance. This is one place where looser is better. I aim for .004"+ difference between pin and gear bushing bore. .005" is better than .003" Others may differ.
Jeepbone1
- First Name: Brad
Post
by Jeepbone1 » Wed Sep 23, 2020 1:10 am
Allan wrote: ↑Wed Sep 23, 2020 12:34 am
I just set mine up with 0.004+ish clearance. Spin like a dream!
Brad
J and M Machine
- Last Name: Gulbankian
Post
by J and M Machine » Wed Sep 23, 2020 8:21 am
Just so everyone knows the triple gear pins are pressed out towards the magnets as the pressed portion is a different size in flywheel.
I would be aware of the hardness of the triple gear pins as we just did a flywheel assembly and the pins weren't hardened properly.
What I mean by this is when i received pins I noticed there were scratches on them. Typically the pins are hard but i took a file and went across the end and I was able to remove some metal. Meaning the pins are soft and will wear out prematurely.
As Mr.Jelf mentioned about wobbling I would also be aware that some flywheels that pins had pins replaced may be cracked.!
There is one triple pin hole that lines up with magnet and dowel hole of flywheel and they always crack there.
Just a word to the wise to be aware of quality of parts being made.
We set the triple gear bushing fit to .003"
- Last Name: Hatch
- MTFCA Number: 49974
Post
by Dan Hatch » Wed Sep 23, 2020 9:12 am
Look into ballizing or ball burnishing. This is for the bushings.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Post
by Dan McEachern » Wed Sep 23, 2020 1:14 pm
Just an FYI to all. I'm going to start production of the triple gear pins in the next few months. We have the steel on order for the 1st batch now. The pins will be made from a chrome-nickel alloy steel, properly heat treated and ground to size. This project is an outgrowth of making the special pins that are used with my needle bearing triple gear conversion. I've had multiple requests from experienced shops and individuals for a higher quality part, so I plan to make the 1st batch and see what the demand is. These will be available in various press fit diameters to accommodate different flywheel sizes. Thanks all.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Post
by Henry K. Lee » Wed Sep 23, 2020 5:51 pm
I received some sets from Dan and can say.., “WOW” very nice and quiet! Super work Dan!
Thanks,
AdminJeff
- First Name: Jeff
- Last Name: Stevenson
- MTFCA Number: 50006
Post
by AdminJeff » Wed Sep 23, 2020 9:50 pm
I can say the triple gear pin bearing upgrade from Dan is rock solid and worth a look. Just a really, really happy customer. The pic on the bottom is what it prevents, especially when you climb as many massive hills as I do.
Jeff
CarreyDM
- First Name: Gerry
- Last Name: Hillstrand
Post
by CarreyDM » Wed Sep 23, 2020 10:53 pm
Jeepbone1 wrote: ↑Tue Sep 22, 2020 12:49 pm
Brad
Sounds like they know their stuff to make the best fitment!
