'26-'27 body blocks
Posted: Thu Sep 24, 2020 10:13 pm
by Mustang1964s
I found a bunch of body block for a '26-'27 T in my father-in-law garage.
Trying to research where they belong, it seems that go on a roadster or coupe.
Does the touring car need blocks?
If so, where can I find where they go? I have been under the '26 T, and have not seen any place for blocks.
I am replacing all the interior wood and have a lot of left over pieces. It seems that the T is either a really late '26 or a '27.
Thank you,
Re: '26-'27 body blocks
Posted: Thu Sep 24, 2020 11:24 pm
by Altair
The blocks go in between the frame at the rear engine mount so that you can tighten the rear engine mounts and not crush the frame. There will be a number stamped on the frame right under the passenger door that will tell you the year and month.
Posted: Fri Sep 25, 2020 6:13 am
by Roffe
I googled and found this on Antique Auto Ranch.
http://www.antiqueautoranch.com/montana ... yBlock.htm
