***1910-1911 2 Piece Driveshaft Cross Section***
Posted: Mon Sep 28, 2020 7:58 pm
The hardened sleeve 2596 didn't appear until 1911 with the tapered end driveshaft, where the pinion gear is held by a nut and cotter pin, instead of the pin rivet arrangement.
The Driveshaft has a hardened end step that the roller bearing 2890 ran on (not sure how, probably case, it would be easiest). I'm assuming that it was deemed much cheaper to make a separate sleeve, harden it and just press it onto the end of the shaft rather than this method, which I can see there being some problems with, especially fitting that rivet.
