Brake drum thrust washers Question
Topic author - Posts: 50
- First Name: lorenzo
- Last Name: leon
- * REQUIRED* Type and Year of Model Ts owned: 2 doctors coupe
I have the the gear shaft and flywheel on crank ready to go , but i cant get the thrust washers to go down on the flywheel hole all the way down i dont want to force them in , Question -can i grind the edge of the 3 washers down some to fit them in ? Thank you for any info--
Lorenzo
Lorenzo
- MTFCA Number: 16175
- MTFCI Number: 14758
Re: Brake drum thrust washers Question
No thrust washers go in the flywheel hole. Maybe a photo would clarify what you're asking.
- Last Name: leon
pictures this is a 26 trany
- Attachments
- 100_1494.JPG (125.36 KiB) Viewed 1737 times
- 100_1496.JPG (137.53 KiB) Viewed 1737 times
- MTFCA Number: 121
- MTFCI Number: 16310
The best thing to do is read the Ford Service book! The reason those washers won't fit is because they don't go there!
- MTFCA Number: 14972
- MTFCI Number: 15411
That's NOT where they go - they go on before the clutch drum !
- Last Name: leon
Yes thats right,. Thank you all for the input
Use the MTFCA Transmission book and/or Mike Bender's Model T-Tips videos on YouTube.
- MTFCA Number: 28924
Wrong location. I use the Ford service manual when I put a T transmission together. Or at least refer to it before I put a T transmission, differential or engine together. I’ve rebuilt a few T components but a refresh of what I’m going to do keeps me from doing the wrong thing. Been there and done that.
