23 t rear axel rebuild
Rich Huggins
First Name: Rich
Last Name: Huggins
MTFCA Number: 50661
Post by Rich Huggins » Fri Oct 02, 2020 10:09 pm
Looking for axel drive gears ! The right side gear in the differential bad and the right top diff cover grooved also, can not get axel out of ring gear diff housing used a plastic hammer on it and my brass hammer did not come out ,the axel rotates but when you hit it it dose not rotate, hit with care. Axel keepers are removed so i cant tell if there is damage to the drive gear or the ring gear. Diff did have babbitt bearings worn on right side, Axel and the wheel would move in and out on the right side , driver side is fine no play no noise from the rear axel! the drive gear #2520 b
MTFCA Number: 16175
MTFCI Number: 14758
Re: 23 t rear axel rebuild
Post by Steve Jelf » Fri Oct 02, 2020 10:25 pm
1 Are you using the MTFCA Axle book?
2 The 2520 differential gears are usually OK, but if you need one try Bob's.
I'm not sure I understand the rest. Maybe pictures would help.
First Name: DAVID
Last Name: HJORTNAES
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Sat Oct 03, 2020 12:24 am
Bob rebuilds the differential halves. He probably also has all the other parts you need to replace.
Rich Huggins
First Name: Rich
Last Name: Huggins
MTFCA Number: 50661
Post by Rich Huggins » Sat Oct 03, 2020 1:05 pm
how do i get in touch with bob
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Sat Oct 03, 2020 1:11 pm
Rich Huggins
First Name: Rich
Last Name: Huggins
MTFCA Number: 50661
Post by Rich Huggins » Sat Oct 03, 2020 11:50 pm
Thanks all for info on the2520b gears the right side is grouved realty bad and has a crack at the keyway and the righe difftop cover is grouved also the ring gear side the left the 2520b gear will not come out of the ring gear housing hit medium taps with a brass hammer tomorrow the 2# pound hammer if that don't work i get a bigger hammer it probably will need replacement anyway the rear did not make any noise!!
Last Name: VanOoteghem
Post by Jerry VanOoteghem » Sun Oct 04, 2020 7:57 am
It appears that none of the parts in your photos is reusable. If the axles were loose in the differential gears it's probable that the axles may be no good either. It should take a lot of force to get the gears off of the axle shafts.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Sun Oct 04, 2020 8:55 am
If you decide to buy new axle shafts from Chaffin's, ask them if they have a good set of side gears that they can press onto the new shafts for you before they ship them to you. Saves you the hassle of pressing them on yourself. :)
