26-27 Engine Pans
Posted: Sun Oct 04, 2020 8:49 pm
by ModelTWoods
Can anyone post a photo of the CORRECT engine pans for the improved (26-27) cars. I see the ones shown in Lang's catalog, but would like to see something clearer and closer up. Please post only if you are sure the photo you post is correct (no guesses or "I think so".
Re: 26-27 Engine Pans
Posted: Sun Oct 04, 2020 9:30 pm
by Dan B
Posted: Sun Oct 04, 2020 10:03 pm
by ModelTWoods
Well, its obvious that I have an incorrect set of pans. I need a set with the two hole right side, like Larry mentioned as I have a 27. I do plan to run a conventional intake and carb, but would like the ability to install my vaporizer, if I ever desire to.
Posted: Sun Oct 04, 2020 10:06 pm
by Dan Hatch
Email me at address in pictures. I think I have found another set of original ones. Dan
- 2D92C0C5-B707-4086-87E8-35DEC36BF0C6.jpeg (50.1 KiB) Viewed 1990 times
Posted: Mon Oct 05, 2020 7:10 pm
by jiminbartow
In 2010, I bought a set of ‘26-‘27 engine pans From Snyder’s for the right and left side of my 1926 coupe engine. They are installed between the engine and chassis so they are perfectly level. The set I bought back then fit perfectly and they are very handy for Holding tools and catching dropped nuts, bolts, washers and cotter keys when working on the engine. I see no reason why a design that fit my car so perfectly In 2010 would have been changed, so what is sold now should be the same. Jim Patrick
