13T - Gas Lamps Coming Back to Life
Posted: Fri Oct 09, 2020 8:24 pm
Decided to work toward getting functional lamps since I picked up an acetylene generator at Luray. Was able to get one of the oil lamps immediately started up with a new wick. Attached are the pics. The other oil lamp has a leaking base. So will see if I can seal up the pinholes then get it lit with its new wick.
For the acetylene head lamps, have parts to order and some supplies. So, I will post pics in the future as I make progress. Don’t plan on operating the lamps often... but want to know they are back in working order if the magic needs to happen.
Darin
Darin
