15 YEARS OLD, FIRST CAR, IT'S DRIVING!!!!!!!
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Mon Oct 12, 2020 9:00 pm
I am 15 and I have a 26 touring. I have had it running for weeks but just got the wheels on and linkages connected. I took it for a 3/4 mile test drive and it drove great!!!! Hasn't driven for 40 years!!!
https://youtu.be/3cuF_WiVv_E
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
ivaldes1
First Name: Ignacio
Last Name: Valdes
MTFCA Number: 50406
Re: 15 YEARS OLD, FIRST CAR, IT'S DRIVING!!!!!!!
Post by ivaldes1 » Mon Oct 12, 2020 9:07 pm
Great work! That was fast, congratulations.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Mon Oct 12, 2020 9:10 pm
Excellent! Looks like the whole family is excited. :)
Mopar_man
Last Name: Govoni
MTFCA Number: 32331
Post by Mopar_man » Mon Oct 12, 2020 9:11 pm
This gives me hope for my 26 Touring. Looking great!!!!
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Mon Oct 12, 2020 9:13 pm
Does your touring run?
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
Stephen_heatherly
First Name: Stephen
Last Name: Heatherly
Post by Stephen_heatherly » Mon Oct 12, 2020 9:15 pm
That's awesome! Getting your car running is really something to be proud of. Congratulations :D
Stephen
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Post by Oldav8tor » Mon Oct 12, 2020 9:41 pm
I hope you realize how incredible it is to be 15 and have resurrected a nearly century old car. I see great things in your future....congrats!
1952 Willys M38a1 Jeep
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Mon Oct 12, 2020 9:42 pm
EXCELLENT!!!!!
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Mon Oct 12, 2020 10:37 pm
And it sounds very nice, too! Congratulations!
GEmering
First Name: Gene
Last Name: Emering
Post by GEmering » Mon Oct 12, 2020 10:47 pm
Wonderful!
Gene Emering
Newton, New Jersey
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Tue Oct 13, 2020 4:04 am
Yeehaw Jonah!
Man oh man, that first drive!
Post by Norman Kling » Tue Oct 13, 2020 11:52 am
I hope you greased and adjusted the front wheel bearings. You very likely did so, but if not, be sure to check them out and grease them before you drive it again. Also be sure to oil the oilers. The T is not like a modern car with sealed bushings which don't get greased. The oil in the T tends to drip out, and water gets in when you go through puddles, so it needs to be oiled often. Every few days if it is a daily driver and before each time you drive it if only occasionally. Also with the splash oil system in the engine, you should let it run a little while before you start driving it, so the oil has a chance to get into the inner parts of the engine.
You sound as though you have great mechanical abilities, and have been very eager to accept advice.
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Tue Oct 13, 2020 12:04 pm
Thank you, I am already starting the process of greasing the bearings. Will axle grece work fine?
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
Jeepbone1
First Name: Brad
Last Name: Kirtner
MTFCA Number: 50618
Post by Jeepbone1 » Tue Oct 13, 2020 12:19 pm
Just go get a bucket of the red stuff from the parts store. I think it’s labeled as wheel bearing grease. Good stuff to have on hand.
Brad
First Name: DAVID
Last Name: HJORTNAES
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Tue Oct 13, 2020 4:27 pm
I just go to the local Farm store to buy grease. I dont like the red because you can see it. The clear that looks like vaseline is what I use. I also use 10W30 oil that I purchase at same store. I also use Prestone antifreeze as I can buy it anywhere. Some generic antifreeze is not compatible with other antifreeze. I use the above oil for my springs and tie rods. Some use chain oil because it is thicker - your choice. Then I put Startron in my tank for the winter, and drain the carb. Nuf said.
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Tue Oct 13, 2020 4:48 pm
What kind of oil do I use on all of tha joints?
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
Post by Allan » Tue Oct 13, 2020 5:16 pm
Jonah, I use chainsaw bar oil. It's very sticky and stays around longer than usual straight 30wt, which is a good thing in worn bushings. Lighter oil in the timer and fan. Others may dis agree.
Well done. That first start always brings a smile to my Son's face, and the first ever drive had him grinning like a Cheshire cat!
2nighthawks
First Name: Harold
Last Name: Schwendeman
MTFCA Number: 0
Post by 2nighthawks » Tue Oct 13, 2020 6:29 pm
Just personal opinion here, but I buy grease cartridges for my grease guns at a marine store. It's especially made for boat trailer wheel bearings, and I just figure that if it's good for boat trailer wheel bearings that are submersed regularly in water during launching (especially salt water) I would think it should also be about the best you can do for Model T unsealed bearings and chassis lube points that are also subject to water as they are unsealed. FWIW,.....harold
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Tue Oct 13, 2020 7:02 pm
Well done young man! Don't stop learning, and don't believe everything you read on this forum! Understand the information in the Ford Service book, and you are on your way. I realize there is little information as far as pictures go in there, but there is plenty elsewhere!
