Head gasket intentionally blocked? Mystery!
Topic author - Posts: 46
- First Name: Bill
- Last Name: Marsh
- * REQUIRED* Type and Year of Model Ts owned: 1913 Speedster, 1914 Touring, 1923 Depot Hack, 1925 Calliope, 1926 Pickup, 1927 Speedster
I pulled the head on my 1926 engine. Noticed that the old head gasket blocks the water passage between the 2 and 3 cylinders.
Do I have the wrong gasket for my engine? See picture. I have a new HG, but still blocks the water. Should I make an opening so the water should go through?
Bill
You can dissect a Model T; but you can’t kill it!
- Last Name: Patrick
- MTFCA Number: 50126
Re: Head gasket intentionally blocked? Mystery!
Does it fit better if you turn it upside down? Jim Patrick
- First Name: Les
- Last Name: Schubert
Some of the holes in the deck were required for supporting the casting cores. The so called “frost plugs” are a classic example!!!
- MTFCA Number: 52564
That hole is on the center line of the block, so no matter which way the gasket is flipped would still cover hole. There is only one way to install the head gasket correct, the water passage holes at front and rear are different size. The holes in the gasket need to match in those locations with the folded over fire rings pointing up. (for the copper gaskets, the comp still needs to be installed with those holes in proper place, but fire rings are crimped on both sides) None of my copper head gaskets have a hole in that location.jiminbartow wrote: ↑Wed Oct 14, 2020 1:05 pmDoes it fit better if you turn it upside down? Jim Patrick
1920 Dodge touring
1920 Dodge touring
- MTFCA Number: 4838
- MTFCI Number: 115
That round hole in the high cylinder head is just a casting feature, the low heads don't have that round hole, both DO have the oval hole for coolant to the block.. All Ford head gaskets will cover that hole, no worries.
Note this Ford high head on left and a modern Z head on right, they both have that round casting hole. But look close at the block these heads are resting on, only the large oval hole is in the block surface.......no round hole on the opposite side.
- Attachments
- zhead and iron (3).jpg (112.54 KiB) Viewed 1980 times
- Last Name: van Ekeren
I'd say, can't check as I don't have any pre 15 blocks in at the moment, that the hole in the block may have been there in early ones? 1913 Parts book shows head gasket as having both water holes and also my stash of old gaskets has one with both holes.
Doesn't the extra hole have to do with the water flowing the other direction down under?
1920 Dodge touring
1920 Dodge touring
- MTFCI Number: 115
An early block, no round hole on the surface, just the oval hole.
And here are the low head (upper one in photo) and high head, note the low head has no round hole, but the high head does have that mystery round hole! Think it may have to do with the casting of the high head, which has larger coolant capacity and that hole likely helped in the sand core pattern.
Dan, that low head looks like it has the gasket still on it, I have several low heads in stock and all have both holes.
