What other Dumb thing did you do today?
Topic author - Posts: 6815
- MTFCA Number: 1219
With the tank sealed and the sediment bulb cleaned and seated I thought I would pour a couple gallons of gas in to test for leaks. Soon I realized I had left the valve open and my gas was spilling onto the floor. A pint always looks like several gallons.
I thought perhaps a place to share them was in order. We could add a NON Model T one on the off topic side.
This is not a competition.
These incidents keep us humble after the successes we have. They are usually more humorous to others.I thought perhaps a place to share them was in order. We could add a NON Model T one on the off topic side.
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
- Board Member Since: 2013
Re: What other Dumb thing did you do today?
I was changing the oil on my daily driver once and forgot to re-install the drain plug. 5 quarts of new oil went right through the engine onto the floor.
- First Name: Jonah
- Last Name: D'Avella
Installed freeze plugs backwards on first radiator test. Two gallons of filthy water on floor.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Too many to list..., on the grounds of self incrimination I am taking the fifth!
Please pass me another chunk of humble pie!
- First Name: Jonah
Here is a slice!
- First Name: Gene
- Last Name: Emering
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
- MTFCA Number: 49671
Removed the inspection cover from the hogshead to tighten the brake band.
Reinstalled finger tight when the misses called me for dinner.
Took the car out for a half-mile test run the next morning.
Washed my driveway and entire neighborhood with oil.
Gene
Gene
Gene Emering
Newton, New Jersey
Newton, New Jersey
- First Name: Henry
- Last Name: Petrino
We all have our share of these stories. Just yesterday I put toothpaste on the hairbrush.
Gene,
Isn't it totally amazing how far a little oil will go?
Gene,
- First Name: Gene
Yes, amazing!
Washed the who underside of my car with oil.
Gene Emering
Newton, New Jersey
Newton, New Jersey
- Last Name: Hanlon
- MTFCA Number: 50191
Look on the sunny side Rich....
You got a nice clean spot on the floor now !!
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
I could write a book on it Rich !
- Last Name: Patrick
- MTFCA Number: 50126
Attempted to top off the oil In my ‘26 coupe by pouring oil into the breather with the engine running. The fan sprayed atomized oil all over me and everything else. Spent the next hour cleaning oil off of myself, the engine compartment, the front fender, running board, firewall, cowl and windshield. All I could do was laugh at my stupidity. LOL! Jim Patrick
- Last Name: Juhl
- MTFCA Number: 50297
- MTFCI Number: 24810
Henry, many years ago when my wife was pregnant I mistakenly put her hemorrhoid cream on my toothbrush. Wakes you up quick!
- MTFCA Number: 4838
- MTFCI Number: 115
Well, not today, but a few weeks ago. Concentrated on neatly wiring it up, then tried first start and T ran bad, sputter and cranky.
While not color blind, did do a mistake on the timer wires to the coil box, seems forgot to do blue then green, so was Dumb on the Start
- Last Name: Kelly
Just yesterday I tightened the center main on the Tudor and missed tightening an inspection cover bolt. Caught it before I had to big of a puddle.
- First Name: Chuck
- Last Name: Griffin
- * REQUIRED* Type and Year of Model Ts owned: 1925 Tudor Sedan
- MTFCA Number: 31570
Didn’t happen today, I was recently working on my 25 Tudor and my work light shorted the generator cutout, fried my ammeter wire. I replaced the wire, ammeter still works. I ordered a new cutout. I’m not sure about the generator, is there a chance of frying the wiring again if the generator is bad and I start the car?
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
Just an observer on this, but I found it outstanding in the "Don't do that!" category:
My SIL took her car to a shop for a tuneup and oil change, etc. She dropped the
car off in the AM and went to work. After work she returned, picked up the car, and
drove away. It ran badly and smoked something terrible. She brought the car by to
see if I might have some ideas. I had no idea a Ford Probe could hold 10 quarts of
oil ! I suspect a mild miscom in the shop had the oil filler guy thinking the oil drainer
guy had already done his work and got right to doing his filling !
- First Name: Jonah
I had a missing screw on the bendix cover and thought it would be fine. First drive in 40 years and it spilled oil the whole way.
- Last Name: Fisher
- * REQUIRED* Type and Year of Model Ts owned: 1924, 1925-ish
- MTFCA Number: 31822
I once assymbled a wheel with the notch on the spokes facing the wrong way. Had them facing away from the hub toword the brake drum. I was on the 3rd one of the day and just wasn't paying attention. Only figured it out when trying over and over to get the brake drum bolted on.
- Attachments
- 2017_0919_08271600-512x384.jpg (39.6 KiB) Viewed 3387 times
Just give me time to Rust and I'll be good as new. Wabi-Sabi
- First Name: David
- Last Name: Mazza
- * REQUIRED* Type and Year of Model Ts owned: 1925 t runabout
Continued to work on the model a engine into model t chassis project, you did say dumb so there ya go!
- First Name: Stephen
- Last Name: Heatherly
I drilled a small hole in my thigh yesterday while working in the garage
Stephen
Stephen
- First Name: Brent
- Last Name: Burger
That will hurt worse tomorrow and the next day than it does now.
I was replacing timbers in a barn fresh pickup body today. There is a timber up each side of the cowl on our Duncan and Fraser bodies. I had it cut to length, had managed to cut the top at the required two angles, had machined the relief for the floorboard riser at the correct angle and depth, had the lapjoint done on the bottom end and proceeded to machine the required taper on the outside face that follows the cowl side panel. Used a mitre gauge to get the angle correct, marked it out on the piece and planed the taper. Only trouble was instead of tapering to the front, I'd made the taper towards the rear!
