Crank modification????
Topic author - Posts: 686
- First Name: Jonah
- Last Name: D'Avella
I was wondering if anyone thought that removing the crank from my engine, and boring a whole in it at a 45 degree angle difference so that I could crank farther without pushing down on it was a good idea? Here is an edited photo with the original crank position in yellow vs the modified position in red.
- Last Name: Rogers
- Board Member Since: 2013
Re: Crank modification????
Jonah- I'm not entirely sure what you are asking but the hand crank has no defined position. You can position it wherever you want prior to starting the car.
- First Name: Jonah
Basically, my theory is that if the handle is rotated 45° different, I will be able to crank two exploding cycles in one crank without pushing down on the crank and it might start better without damaging my arm.
- First Name: Jonah
I can position the crank but not the engine.
- Last Name: Rogers
If everything is up to snuff on your engine it will start easily with a quarter turn of the crank. Are you having trouble getting it started? Some things to consider:
* do a compression check- Ts are notorious for worn out vales and seats. 55 PSI per cylinder would be great
* prime the engine prior to switching on the ignition
* richen the carb before for starting
- First Name: Jonah
If usually starts fine, and the compression is excellent, but it is an unrestored vehicle that has been sitting for 40 years.
- First Name: Terry & Sharon
- Last Name: Miller
- MTFCA Number: 32583
Jonah,
Look up and read some of the many posts on this forum addressing how to crank a Model T. There are several different methods. Some seem to be safer than others. I suggest you try the safe ones and see what works for you. I use my left hand cupped (not grabbing with thumb around the crank handle), facing the radiator, right hand on the left front tire (driver's side) and use my legs, left arm (on the crank), and right arm (on the tire) to get a good quick, hard pull on the crank. This works for many and does not work for many. You have to figure out what works safest and best for you.
Good Luck Buddy,
Terry
Good Luck Buddy,
Terry
- First Name: Jonah
Thanks, I so far have found that that way works best for me , but it is still hard to start.
- MTFCA Number: 16175
- MTFCI Number: 14758
In the past 100+ years there have been millions of Model T's that started easily on a quarter turn, with no alteration of the crank. So your idea, even if it works, is a band aid for a problem that should be fixed. Your T should start like this, with no alteration in the crank: https://www.youtube.com/watch?v=3pv6HWWOGYA.
Yes, I know. It's easier said than done. But your T can be fixed to start easily. My suggestion is to get all the necessary elements up to snuff and enjoy the results.
- Last Name: Bartsch
- MTFCA Number: 30615
Jonah: Read the Model T Joke thread below, it's a very factual answer to your inquiry. jb
- First Name: Jeff
- Last Name: Humble
- MTFCA Number: 28034
- Board Member Since: 2006
Jonah, no need to reposition the crank on the crankshaft, with the key off engage the crank and turn the crank to where you want it for starting, then start it from the new position.
I have read on the forum that some crankshafts do not have the hole for the pin which holds the pulley drilled in the same place. All that I have seen have it in position where number 1 spark comes just after the pulley passes the straight across position with the lever retarded. So if your crank is like that, it is standard. I find that if I start pulling up the crank at about the7 o clock position it will complete the exhaust stroke at about 10 o clock and then come up on compression about 1 o clock. I can get two compression strokes on one pull. As soon as the crank begins to pass 12 o clock I set go. and immediately raise my arm out of the way. \
On a cold engine I always raise the spark lever to retard, the gas lever down about 1/4 of the way, then with the ignition key off, I open the fuel mixture needle one quarter turn counter clockwise. I choke through 3 intake cycles and then turn the key to battery. Sometimes I get a "free" start. If not I crank one upward pull with the left hand fingers around the crank but not the thumb. Raise the arm out of the way. Usually it will start right up. If not I try another pull up. If it doesn't start with 2 upward pulls, I turn off the ignition switch and turn the crank all the way around a few times then turn on the switch to battery and try to start again. The reason for turning off and cranking around if few times is in case I accidentally flood the engine that will remove some excess gas from the cylinders. On a hot engine, such as after stopping to fill the tank, I just retard the spark and crank without any choke.
Another thing to do if it starts up is to quickly run around and advance the spark and turn the key to magneto. This will keep it running until it warms up. When it warms up, you can make a fine adjustment of the carburetor to find the sweet spot.
- MTFCA Number: 4838
- MTFCI Number: 115
Jonah
Your post brought this old 'Hint' from Ford Owner magazine to mind......the crank handle is heated with a torch and bent to bring the pin hole for the retaining pin in the crank ratchet 'in-line' with the grip handle of the crank handle. Places the handle in a better spot to achieve easy start as you desired. Guess it works or did for the submitter in 1919, a Mr. O.D. Chrowl of Dowagiac, MI.
- First Name: Jonah
I have a spare crank an I am going to experiment with that.
- First Name: Dennis
- Last Name: P
- * REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1925 TT, 1927 Speedster, 1931 Model A
- MTFCA Number: 31449
- MTFCI Number: 24373
- Board Member Since: 2012
Jonah, regarding your original question, when you are hand cranking the engine, you will only get a compression stroke every half revolution of the hand crank. It takes two complete revolutions to get all four cylinders over a compression stroke. You will not be able to crank it over two compressions without pushing down on the crank no matter how you bend it or reposition the ratchet on the end by drilling another hole for the pin. I see what you are trying to accomplish, but I'm afraid it just won't work.
- Last Name: Patrick
- MTFCA Number: 50126
Go ahead and try it, Jonah. Sometimes the only way you can determine whether or not something is going to work is to try it and see for yourself. If it works you can report your success. If it doesn’t, you’ll be able to analyze it and determine why it did not work. The best way to learn something is to demonstrate it to yourself, instead of asking.
- First Name: Paul
- Last Name: Robertson
- * REQUIRED* Type and Year of Model Ts owned: Ford model tt 1921 right hand drive
Jonah, I would like to second the advice James has given you.I have spent my working life with tractors and diggers, driving , mending and eventually owning a fleet of dumpers and excavators. I had no formal training and didn't come from an engineering background but I listened to those who questioned accepted practices. Looking at problems from an unbiased and often uneducated view point often produced an easier solution.
Jonah, I like your style, carry on as you are and you will go far!
- MTFCA Number: 121
- MTFCI Number: 16310
Since your car has a starter, why are you worrying about the crank????
- First Name: Jonah
I rather hand starting it than using the electric one.
Doing it yourself rather than asking questions might be just fine on something inexpensive such as altering the crank. However since Henry made so many the same way, it would be presumed that he had determined which way works best. However just as every Model T is not quite the same, so we as people are not all the same.
I would, however, recommend that on anything expensive such as engine rebuilding, or transmission rebuilding, you do your research and also ask local Model T owners and perhaps ask also how dependable their cars are for lasting and touring. Then make your own decision as to which way to go. Remember that the car as Henry built it was very dependable but he did things to keep the price down. All the parts were made to work together, and when you change something you might cause an unintended strain of other parts. Now the position of the crank might not cause a problem with the way the car runs, but it could cause a strain on your arm. Anyway, I like the way you have a spare crank and will experiment with one while leaving the other as it was made.
An example of something similar, I put Ruckstell axles in all my T's, however I kept one original axle assembly so If I have a problem with the Ruckstell, I can quickly change the axle back to standard while I have the Ruckstell out for repairs I can still drive the T. Etc.
Good luck with your car and remember to be safe.
Jonah, if you do decide to alter the cranking angle, rather than re-drill the crank handle, it is simpler to re-drill the dog on the end. Set it in the position you want and drill one side only at first. Then fit the dog to the handle and line up your newly drilled hole with the hole through the handle. Then you can drill through your new hole and the crank hole will keep the drill in line as you drill the other side.
Hope this helps,
Hope this helps,
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
Jonah. In the first sentence in the first post you mention pushing down on the crank. You should never ever be pushing down. Good way to break your arm or your shoulder.
- First Name: Jonah
I am trying to crank better with still being contentious.
- First Name: CHARLIE
- Last Name: BRANCA
- MTFCA Number: 28967
- Board Member Since: 2010
As I see it you have 2 great suggestions here. 1; bend a spare crank and 2; re-drill a spare dog. Leave the crank itself alone.
- First Name: Tony
- Last Name: Bowker
- MTFCA Number: 32
I don’t believe moving the hole on either the crank, dog or crankshaft will not do what you wrote in the first thread. There are two compression on each revolution of the crankshaft. It follows that there will be one compression for each half turn of the crankshaft.
You can move the alignment as to where you get the compression on any half crank but you cannot get two compressions on half a rotation.
Neat idea but I’m afraid it will not work.
Tony Bowker
La Mesa, California
La Mesa, California
- Last Name: Rogers
The position of the hand crank is dependent on the position of the engine crankshaft. Bending, twisting or re-drilling the hand crank will not alter this fact.
As stated earlier, with the ignition off just position the hand crank where you want it by rotating the crankshaft.
- First Name: Joe
- Last Name: Reid
- MTFCA Number: 52067
- MTFCI Number: 22088
Fix the starter and use that. Much easier,
As has been said several times in this thread, you can position the crank at any position you want by engaging the ratchet and lifting on the crank to get it just right, but beware. If your engine is well adjusted and starts easily, your engine could roar to life as soon as it makes contact with the first spark coil it causes to buzz. By the same token, it could also backfire under the same circumstances of positioning the crank at precisely the position You desire, however, if your arm is in the way when the crank spins around in a counterclockwise direction and smashes into your arm, one or more times, you will be spending Thanksgiving in a cast. Positioning the crank should not be made more complicated or important than it is. Position it at 7:00 and crank it. It is not complicated. Be careful and stay safe. Jim Patrick
- First Name: David
- Last Name: Stroud
- Board Member Since: 2011
Leave the crank alone, it has worked for over 100 years as is just fine. JMHO Dave
1925 mostly original coupe.
- First Name: Robert
- Last Name: Thompson
Jonah, I had the same idea with my friends 1913 T. When I would try to start it by pulling the crank straight up ,it would stop at the twelve o'clock compression stroke. I explained as not getting "over the hill". All I did was change my cranking position. Instead of pulling straight UP with my left hand (9:00 to 12:00) I would pull at a angle about 9:30 to 1:30) and this worked for me. On MY 1915 T' I still pull straight UP and it starts fine. I hope you understand what I'm trying to say. bobt
