Help needed with Wrench identification
Posted: Sat Oct 17, 2020 10:10 am
by Ed Fuller
I came across this wrench when I was digging through a pile of T parts. I am curious if it is for an aftermarket wheel hub. Does anyone recognize it?
It measures about 2 3/16” to 2 1/4”.
Re: Help needed with Wrench identification
Posted: Sat Oct 17, 2020 11:44 am
by sweet23
That may be a Fordson wrench
Posted: Sat Oct 17, 2020 5:48 pm
The fourth spanner from the bottom is the earlier spark plug wrench with the socket end. Later versions had an open box end. The pliers above that spanner are just like those Ford used, but the more desirable ones are Ford branded. There are so many unbranded pliers that it may be that they are indeed Ford issued. The same goes for tyre levers. They are unbranded, except for some of the Canadian ones.
