Gasoline Evaporation "Tip"
Posted: Tue Oct 20, 2020 4:16 pm
For what it's worth, I have solved a problem that I have experienced several times during a lifetime of Model T and Model A ownership. Not sure how many others have had similar "experiences", but I have had several instances whereby partial tankfuls of gasoline have COMPLETELY evaporated when a car was inadvertently left unused for a whole season (or longer) and slow as I am to "catch on", I have discovered a way to eliminate this problem. On several occasions during the last few years, I have let a "T" or an "A" set for several weeks before finally realizing that I will probably not be driving the car again for quite a period of time, like for instance, in the Fall, when I finally realize that the car will probably be left idle until at least the next Spring. Upon such "realization", I apply a little piece of tape (black plastic electrical tape works well) over the vent hole in the gas cap. Knowing my ever-failing memory now that I'm crowding age 80, I also stick a little piece of matching "reminder tape" on the steering wheel as a reminder for several months (or maybe longer) the next driving season. Here's what I have decided actually happens if you don't do this with a partial tank of gasoline:
One of the Model T's that I leave in a garage all winter is a perfect example of what I believe happens. The garage gets fairly warmer during the daytime, and considerably colder at night. This constant daily/nightly temperature change all winter long, causes the gasoline tank and the volume of air inside the partially empty (or partially full) gasoline tank to actually "breathe" (like inhale/exhale) thru' that tiny little vent hole, on a daily/nightly basis, all winter long. Believe it or not, a "several gallon" quantity of gasoline will completely evaporate over such a long period of time. I also believe that this also why some of us "T" owners have problems with the modern gasoline (which is "hydroscopic") causing the hard-starting problems that some of us have experienced.
I'm curious how many other folks have, at one time or another, experienced a partially full (or empty) tank of gasoline to completely and "mysteriously" completely disappear over a period of time,...????
As always, just my "opinion" of what actually happens and one way to prevent it,....for what it's worth,....harold
