Wiring Harness Question
Posted: Tue Oct 20, 2020 5:20 pm
I was working on my 25 T sedan not paying attention to my work light when my wiring harness and cutout started smoking. I pulled the wire off of the cutout it stopped. My work light has a magnet on the back, it must have stuck onto the cutout and closed the points, turning my generator into a toaster. My question is what gauge wire is acceptable to use to replace the burnt wires? Also, would I be correct in assuming my generator is toast?
