Question About Holley G Carburetor
Posted: Sat Feb 23, 2019 1:26 pm
I recently got a Holley G carburetor with an unusual (at least to me) Throttle lever setup. It has the Dec 22, 1914 patent date on the top. The extra part is 1 1/4" tall and has a label that says "Apex Elec Mfg Co, Made in USA, Chicago". It has a thin slot that can be seen in the first picture and a similar slot in the shaft that is only about 1/4" tall. I'm not sure the purpose of these slots.
Any suggestions as to why these parts were added and what is the purpose for extending the throttle arm upward? Is the throttle arm installed correctly or should it be inverted before tightening to the shaft?
Thanks for any help.
