Battery relocation
Topic author - Posts: 216
- First Name: Brooks
- Last Name: Schlieben
- * REQUIRED* Type and Year of Model Ts owned: 1923 TT
- MTFCA Number: 32304
Battery relocation
I would love to bring my battery indoors in that that the T sits under a carport. Cold weather becomes an issue. With the current cables, are there extenders I could use, so that I could move the battery to the turtledeck area? I guess I could buy longer cables, but the ones I have now are correct and want to keep it original. Pulling it out the holder is a task in and of itself, and would like to be able to remove the battery quickly. Thanking you in advance for any thoughts!
- Last Name: Stroud
- Board Member Since: 2011
Re: Battery relocation
Brooks, I use a battery maintainer on our '25 coupe. It lives in the unheated garage all winter. Works for me. Dave
1925 mostly original coupe.
I second what David said. Our one starter car is presently residing in a shop/barn that is right now, 2F. I go out once a week and plug in the cheap battery maintainer and within 30 minutes, it shows the battery to be fully charged. The last few years I'd just let it sit for 5 months and it would still start. Battery is now 5 years old and last summer was too pooped after 5 months sitting to crank...hand cranked it up and generator replenished battery. Now, with the maintainer on this winter, I expect the car will start just fine in spring. I tested it last week and it turned the motor over just fine at 10F.
Bottom line, buy a maintainer and run an extension cord to it...like I mentioned, mine only takes 1/2 hour every week or so to keep things up to snuff.
NH Full Flow Float Valves
- First Name: Val
- Last Name: Soupios
One of my cars sits all winter in the garage of our summer house where the temperature inside has gotten as low as 15 below zero. I keep a "smart" battery maintainer on it all winter and have never had a problem. I just bought a new battery last year and the old one was 7 years old.
Many thanks, guys.
I will do just that!
At the local auto parts store you can buy a strap with two ends which fit over the terminals and when you pull up on the strap they tighten around the posts. With this tool you can pull the battery right up and out of the box. Wherever you locate the battery, it should be firmly attached so that it won't roll over as you drive the car. And if you pull the battery, you can bring it indoors to keep it warm. But it still should be kept in a fully charged state but not overcharged to last a long time.
- Last Name: Heavner
- * REQUIRED* Type and Year of Model Ts owned: 1920 ruabout
- MTFCA Number: 31779
I keep a battery maintainer on my '20. My car sits in an unheated garage. I didn't know about the tool to pull the battery so I made a wooden holder the battery sits on and pull it out with para cord. My original battery bracket had rusted out and been repaired, so it was easy to make a holder to put in the original bracket for it to sit on. I will check out the battery puller the next time I'm in a parts store.
- First Name: Aaron
- Last Name: Griffey
- * REQUIRED* Type and Year of Model Ts owned: 1926 touring
Do you really think moving the battery to the truck will keep it warmer than in the battery box?
- MTFCA Number: 52564
Because of today battery construction, we should not be using the post to lift the battery up. Yes I do it too, but if you do some checking there has been information put out there that says not to. The cases are not as thick and strong as they use to be. I don't think the clamp type will fit thru the door anyway so we really don't have a lot of choice other then to try and reach down and lift up or use the post type lifters.
1920 Dodge touring
1920 Dodge touring
- First Name: Jim
- Last Name: Riedy
- MTFCA Number: 25079
- MTFCI Number: 18732
I find it easiest to disconnect the battery then climb underneath and push it up and over to the side, then I can dust pick it out of the trunk. Jim
- MTFCA Number: 16175
- MTFCI Number: 14758
For removing a battery from the box, plan ahead. Install it with a strap around it to use as a handle when you have to lift out.
