Robert m Roof 16 valve head
Posted: Sat Oct 31, 2020 2:54 pm
by Shelbycsx
Does anyone know what year this model head was first starting to be produced? How many did they make?
Re: Robert m Roof 16 valve head
Posted: Sat Oct 31, 2020 4:35 pm
by StanHowe
John Steele has several of those 16 valve heads and reproduced the racing manifolds for them several years ago.
If you want his contact information email me at
stanhowemt@aol.com and I will hook you up.
Also, you should sell me that Carburetor!!!!
Posted: Sat Oct 31, 2020 4:46 pm
by aDave
Stan, you keep saying how many you have now...and how much work is ahead of you.....you'll have to live longer than Methuselah to finish all your projects! That pretty violinist of yours will not have time to do the carbs and play also!
I know....long winters up there....but still....
Be well.
Too much carb work, and there won't be time for another book.
Cheers,
Dave
Posted: Sat Oct 31, 2020 4:51 pm
by StanHowe
John is off hunting so I'll just tell you what little I know about it. That is an A head, the first of the Roof 16 valve heads. The intake manifold bolts to the side of the block, the exhaust to the side of the head.
It was replaced by the B, then the BB, then the C. The C is worth several times what the A or B is because it flows much better as the intake is also on the head.
Total of my knowledge right there.
Posted: Sat Oct 31, 2020 4:54 pm
by David Mazza
Short video of one running, sounds awesome, and powerful!
https://youtu.be/Ld3D-nEnSlY
Posted: Sat Oct 31, 2020 4:55 pm
by Kevin Pharis
This article states that Laurel began marketing the 16 valve heads in ‘17-‘18. It’s not specific enough to discuss when the various models were released tho...
http://www.coachbuilt.com/bui/l/laurel/laurel.htm
by StanHowe
David, I am not buying carbs much anymore. I bought a Master the other day because it had the correct original manifold for it. Hope to have it sold and paid for before Christmas, I am trying to round up money for a set of Sure Stop brakes for my coupe.
I'm gaining on the pile, cranking them out day by day. Been in the shop since about 10 this morning, headed back out in a few minutes.
Savanna is a Jr at Stanford. Not much time for fiddle playing but is playing in a couple Jam Session groups, one Bluegrass/Old Time and a Western Swing one.
Posted: Sat Oct 31, 2020 5:01 pm
by StanHowe
THAT IS JUST COOL!!!!! I HAD FORGOTTEN THAT MIKE ROBISON IN SPOKANE HAD A 16 VALVE (if I ever knew)
Posted: Sat Oct 31, 2020 5:23 pm
by Shelbycsx
Is the master carb rare? What year did they make this model?
Posted: Sat Oct 31, 2020 5:33 pm
by StanHowe
Probably somewhere between "Rare" and "Not too common." I just bought a couple of them yesterday, have probably 4 or 5 of them on the shelf. They came in various sizes and were popular with the racing crowd. They are better for racers than for everyday driving. They came out in the late teens and were built up though the late twenties. The smaller Masters seem to be rarer and worth more than the larger ones.
There are several others that are much rarer than Master. Some are just made of unobtainium.
Posted: Mon Nov 02, 2020 12:09 am
by Shelbycsx
The B head came out in 1918. I found a number 270 stamped above the water outlet could this be the serial number, anyone else have a number there.
Posted: Mon Nov 02, 2020 11:24 am
by Tom_Carnegie
Stan, Mike Robison does have a 16 valve Roof, but this video
https://www.youtube.com/watch?v=Ld3D-nEnSlY&t=7s is not of his. That is a Roof that I put together for Gil at the Miracle of America museum in Polson, MT. It came to me as a bucket of parts with stuff missing. I don't remember exactly what I did, but I had to make a bunch of stuff for it. The trick to making a Model A Roof run good is PC seals on the push rods.
Posted: Mon Nov 02, 2020 11:30 am
by got10carz
Here are some pictures of my 16 valve. It is a Model BB with 1 1/2" valves in a square pattern. This motor had Laurel pistons, Laurel aluminum rods, Luarel camshaft and radiator when I found it. These are the better rocker arms, than earlier versions. If I remember correctly the Model A head pictured above had push rods that went through the intake ports, creating a possibility of vacuum leaks, and bad idle.
Posted: Mon Nov 02, 2020 12:18 pm
by Shelbycsx
I heard about the leaks through the pushrods. The guides on top of my head look different from others I've seen. 4124 sounds about right for the BB head serial number. I'd be curious to what other A head serial numbers are. They said rajo made over 4,000 heads.
Posted: Mon Nov 02, 2020 12:33 pm
by got10carz
Just for a discussion, do you suppose mine was the fourth model, remember that there is an 8 valve, 124th head of this model. The 4000 RAJO # seems small. They are everywhere. Perhaps Mark Chaffin, or James Roof will chime in.
Posted: Mon Nov 02, 2020 12:43 pm
by Shelbycsx
Roof made a 16valve C head yours will be third model
Posted: Mon Nov 02, 2020 10:09 pm
by Kevin Pharis
I stumbled across these a while back... it’s no surprise the push rods can become a major vacuum leak
Posted: Mon Nov 02, 2020 11:19 pm
by StanHowe
Interesting!! I've never seen but one or two Roof heads.
Also interesting is the carb on the one Steve Meixner posted. That is either a U5 or U6 Zenith. Great carbs with a brass venturi. Hard to find that aren't all beat up and missing stuff. I am working on one for an overhead setup for some body in California. Interesting that one is on an original.
Zoom Zoom!!
