Model T front fender brackets
Posted: Sun Feb 24, 2019 1:05 pm
by John W
Are the front fender brackets made of cast iron or cast steel?
Thank you
Re: Model T front fender brackets
Posted: Sun Feb 24, 2019 1:14 pm
by Jim Sims
Not cast iron. Either cast or forged steel.
Posted: Sun Feb 24, 2019 1:30 pm
by Humblej
For what year are you asking?
Posted: Sun Feb 24, 2019 3:22 pm
by John kuehn
They are made of some steel I believe. They are not being reproduced for the most part. These are one item that ought to saved when junking old T fenders that are to far gone to repair. They usually out last the sheet metal fenders.
Posted: Sun Feb 24, 2019 3:35 pm
by Russ T Fender
They are forgings. They can easily be bent cold and often the ones you find have been bent over the years as a result of accidents and people sitting on the fender.
Posted: Sun Feb 24, 2019 4:22 pm
by Wayne Sheldon
It makes a big difference whether you are talking about the frame to fender "irons" which are most often called "fender brackets" as opposed to the somewhat more correct "fender irons" (for 1909 through '25, the '26/'27 is a totally different animal and I have never owned one myself)). Or are we discussing the "bracket" that is riveted to the fender itself which is then connected to the frame to fender irons?
The reason I mention all this is that I see some of the answers above refer to one, some to the other.
Colloquialisms. Why is it always colloquialisms.
Posted: Sun Feb 24, 2019 6:42 pm
by John kuehn
From what I have come to understand and from Ford parts books fender irons are the 4 iron fender irons or maybe fender supports that hold the fenders to the car itself.
Fender brackets are the brackets that the fender irons attach to that are riveted under the crown of the fenders. Those are the brackets I was referring to that aren’t being reproduced.
Posted: Sun Feb 24, 2019 7:20 pm
by DJPeterson
The fender brackets as defined above are stamped steel, riveted to the fenders.
