Fixing flats.
Posted: Sun Nov 01, 2020 1:53 am
I have just come home from a 3 day tour run by our T club, and have to report some firsts for me, and a few notes of caution.
A very nice 14 T tourer had a flat tyre just as we pulled up for a catered lunch stop. In all my years of model T motoring I have never fixed a flat tyre on the roadside on a non demountable wheel, and neither had the new owner of the car. He had a jack and some tools stowed under a mountain of luggage under the back seat, but knew there were no tyre levers among them. He did have a replacement tube inside a spare tyre carried at the back of the car. I could supply a jack from my running board toolbox, so he didn't have to unpack the luggage, but we were still short of tyre levers.
Then I remembered I had a tool roll of original T tools in the toolbox with the jack, and in that there were 3 of the short T model tyre levers!
In another first for me, these levers did the job! The tyre was loose on the rim having travelled a short distance while flat. It was an old stock Dunlop tyre made in the late 60's and was really quite supple and easily removed. We stuffed the replacement tube into the tyre, inflated it just enough to hold its shape, and went to fit it. Fortunately, we were able to rat a valve stem extension from a front wheel, as the valve stem on the replacement tube was not long enough to get an air chuck onto the valve. I fitted both beads and the valve stem into the rim and lowered the jack to hold them in place while we levered both beads back onto the rim. Someone came forward with a rubber mallet to complete the mounting.
Then we had to inflate it. One helpful soul offered his pump, minus the chuck. He suggested that we could jam the hose down over the stem and blow it up that way, I'll leave you to work out how that was not going to work. A second pump had a faulty chuck that would not depress the valve core stem and leaked anyway.
Finally, a portable compressor carried by a driver in a modern car completed the job.
Some lessons were learned. If you have to change a tyre, you need tyre levers. You need to be able to repair a puncture or carry a replacement tube. If you need to inflate a tyre, you need a working pump. Finally, if your rims are prone to liberating flakes of rust, you need a rim liner, or if you have plenty of funds, a flap.
