Interesting T on Epay
Posted: Tue Nov 17, 2020 2:39 pm
by Angmar
Note the drum brakes on this car...
https://www.ebay.com/itm/1925-Ford-Mode ... SwCe1fss0z
Re: Interesting T on Epay
Posted: Tue Nov 17, 2020 3:12 pm
by Rich Eagle
Hydraulic no less. Many improvements to that one.
Interesting!
Posted: Tue Nov 17, 2020 7:45 pm
by dhosh
Wonder why the 2 sets of switch/ammeter plates? Looks like a disconnected oil pressure switch on one side, and a disconnected heater on the other...
Posted: Wed Nov 18, 2020 12:23 am
Was wondering about the two switch plates too. There are several wiring modifications, modern starter solenoid think is 12volt has 2 ears, extra starter switch on dash, electric wiper motor, brake line switch and alternator. There are also some black wires going to the upper row of the coil unit connections plus many loose connections. It appears that one switch plate, with the key has a Magneto meter in it while the key-less one has an ammeter.
Previous owner an electrical engineer and set it up for dual voltage; magneto and 12 volts. :roll:
Posted: Wed Nov 18, 2020 8:37 am
by Susanne
Had to have some kind of water pump to feed it - I'm guessing that's where the cabin heater was fed from, and returned to that fitting on the top of the head. Otherwise you would get no water flow unless it was out on the ground.
All the electricals make me wonder what this person was doing - I suspect there was more afoot with this car in it's past and some of the goodies that were once on it were changed out.
All in all, it IS quite the fun puzzle to work out!
Posted: Wed Nov 18, 2020 9:42 am
by John Codman
I'm guessing that the water outlet at the top of the head was the heater inlet and the return went to the bottom of the radiator there's no reason why convection wouldn't feed the heater. It looks like a nice little car, but there is a lot of stuff that I would want to undo. JMO.
Posted: Wed Nov 18, 2020 11:15 am
by BHarper
This car is, I think, set up as a good daily driver and all of its updates causes me to wonder just how late it was used as a daily driver? Into the 1950s? Even later?
I LIKE this car! Well, the seat upholstery, not so much.
I have on my bucket list to do some long distance touring and camping in my '24 coupe. I know that the most reliable cars on any tour tend to be the ones which have remained largely stock, with the allowances for Ruckstells, Rocky MT brakes, and their ilk.
But THIS car, hmm.
My '24 coupe.
Posted: Thu Nov 19, 2020 10:04 pm
by dhosh
"Previous owner an electrical engineer and set it up for dual voltage; magneto and 12 volts."
Two totally separate electrical systems, then. Guess that makes sense.... You know those electrical engineered! LOL!!
Posted: Fri Nov 20, 2020 10:29 am
by John Warren
Most mods look old. I like the brakes for touring, heater might also be a good thing. It would be a great car to use. Of course the brake system needs to be looked at very carefully , as with any mod.
Posted: Fri Nov 20, 2020 5:11 pm
by John Codman
I guess that I'm the odd man. It would cost quite a bit to return it to original. I wouldn't pay anything lose to what the seller wants for it, but at a significantly lower price I would be interested.
Posted: Sat Nov 21, 2020 8:22 pm
by OilyBill
John Codman hit the nail on the thumb.
A lot of mods, and IF they were well done, it MIGHT be a good car.
But if they were all botch jobs, then you would have a LOT of work ahead of you, getting it drivable and also RELIABLE.
I think that might be why the price is so low. When I see mods on a car, especially older mods, I get VERY wary, and to me, the price goes DOWN rather than up for each "improvement" that I see on the car. I know that each one I find is going to take hours to disassemble, clean, and inspect to see if it was done well, or just hacked, and now needs to be straightened out, with a lot of wasted time and money.
There is no telling where they guy drilled holes, did a little welding, etc, etc thinking he was "improving" the car.
Like being hot-rodded, Model T's getting "improved" is rarely a good idea.
I think far more highly of cars that have been well-maintained, well adjusted, and well-lubricated rather than "improved"
just my 2 pfennigs.
