Ring and Pinion set #1
Posted: Fri Nov 20, 2020 1:57 am
Set #1, Ford gears.
Pinion gear is as perfect as one would hope to find. Bore and keyway look great, no chipped teeth or pitting. Ring gear has no pitting or chipped teeth although 5 of the teeth show some wear across the tops.
I tried to show the best I could in the pictures.
I don’t know for sure if they were actually a set that were run together. I got these in a pile of parts I bought and they were not wired together. They have been bead blasted to remove light surface rust.
$175 plus shipping.
Scott Elliott
971-5O6-94O2
$175 plus shipping.
Scott Elliott
971-5O6-94O2
