Spring for Hand Brake?
Topic author - Posts: 2477
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
In the Nov/Dec issue of Model T Times Dan Treace mentions an accessory ratchet pawl spring. Is this available or do you need to make one? Is it made from a commercially available spring? Thanks all.
- MTFCA Number: 52564
Re: Spring for Hand Brake?
The suppliers should all have them in stock. https://www.modeltford.com/item/3463R.aspx
1920 Dodge touring
1920 Dodge touring
- First Name: Christopher
- Last Name: Instness
- * REQUIRED* Type and Year of Model Ts owned: 1915 runabout, 1923 speedster
- MTFCA Number: 52552
I have one on my speedster. Works great.
- MTFCA Number: 16175
- MTFCI Number: 14758
I used a spring from the local hardware store. No shipping.
- MTFCA Number: 14972
- MTFCI Number: 15411
A suggestion on using the accessory spring - as it is quite strong, I recommend squeezing the release handle whilst pulling on the brake handle to alleviate premature wear on the pawl & ratchet !
- Last Name: Gould
Amen to your suggestion Steve!. I totally wore out the tooth not squeezing the handbrake lever when pulled back. Learn by ruin
- Last Name: Stroud
- Board Member Since: 2011
The handbrake lever should ALWAYS be squeezed when the brake is applied, no matter how stiff the spring is, or isn't. Same thing goes for any other similar type of ratchet type of system. Learned that by being around farm equipment over 60 years ago. Just makes sense. Dave
1925 mostly original coupe.
