What is the difference between a Model T and Model A Crankshaft?
Posted: Mon Nov 23, 2020 9:29 am
by Catbird
I have heard about people installing a Model A crankshaft in a Model T. What are the advantages? Also, how can I tell if my 1927 Model T speedster has a Model A crank from past owners?
Re: What is the difference between a Model T and Model A Crankshaft?
Posted: Mon Nov 23, 2020 9:37 am
by Henry K. Lee
More torque from the stroke for sure. Larger journals, but some serious mods. Drop the inspection plate and you will know.
Posted: Mon Nov 23, 2020 9:45 am
by tman1913
If the front of the crankshaft at the pulley is threaded and the pan has four bumps on each side where it is bolted to the block, there’s a good chance you have a Model A crank
Remove the inspection cover and have a look
A Model crank has larger mains and rod pins along with a 1/4” longer stroke.
Take a lot more work to put one in but very doable
What Henry said. He types faster. Lol
Posted: Mon Nov 23, 2020 10:55 am
by Kevin Pharis
Here is a pic of the pan bumps... and there will usually be a 3/8”-1/2” thick spacer between the pan and inspection cover as well
If you have the inspection pan off, and are not familiar with either crank... the A crank has circular webs near the main journals, and the T crank will look like it was bent up out out of a coat hanger👍
Posted: Tue Nov 24, 2020 12:27 am
by TonyB
I can usually tell if it’s an A crank by the “bumps” on the side of the pan.
Posted: Tue Nov 24, 2020 9:46 am
by Catbird
Good info! Will check into my engine.
Posted: Tue Nov 24, 2020 6:41 pm
by otrcman
Somebody correct me if I'm wrong, but I think one of the most significant differences is that the Model A cranks are virtually never found cracked.
Posted: Tue Nov 24, 2020 7:49 pm
by Tim Rogers
Model T...
Model A...
Posted: Wed Nov 25, 2020 7:09 am
by Catbird
Thank you, Tim Rogers. Opened your post while my wife brought my coffee this morning! She also likes cars. I asked her could she see the difference between Model T and Model A crankshaft. She immediately saw the difference! She said, "The Model A looks 'newer.' " :roll:
Posted: Wed Nov 25, 2020 10:04 am
by J1MGOLDEN
The back Main Bearing is also shorter by about 3/8th inch.
I don't recall the exact difference.
