Summary: I’m 99% sure you have a wheel/felloe that was manufactured by Firestone on or after Mar 1924 for use in the Ford USA assembly plants and as a replacement part for dealers.
Additional Details:
John – thank you so much for finding and posting that Patent information. From the second page it has:
- Firestone Steel Products patd Sept 27 1921.JPG (22.9 KiB) Viewed 2962 times
That it is a patent for a demountable felloe and rim and that it was Patented Sept 27, 1921 i.e. 9-27-21 which is the same date stamped into the metal felloe indicate it might be the same felloe and rim. If the Patent date was different then it probably would not have been the patent for that wheel/felloe/rim. Initially I saw the Jan 25, 1919 date and thought – well this patent is not for that felloe/wheel. But then I zoomed in and read that was the date the Patent was applied for NOT when it was Patented.
Looking at the illustrations in the Patent, it is close but NOT a perfect match for the felloe you show in the photo you posted. But on page 2 of the Patent it has:
And that indicates to me that they could make minor changes and still keep their patent.
And the Patent states ASSIGNOR TO THE FIRESTONE STEEL PRODUCTS (see below)
And note that the word “COMPANY” is on the next line. That lines up with the F-S-P-CO very well.
Looking at the information from Bruce’s Encyclopedia at:
https://www.mtfca.com/encyclo/U-Z.htm#wheels we see that Firestone supplied demountable wheels and parts for the USA Ford Assembly lines as well as for replacement parts. (So did Hayes, Kelsey, Cleveland, Motor Wheel and possibly others.)
But from the photo you posted your felloe does NOT have the cup around the valve stem for the lug on the rim with the removable lugs so your felloe is NOT for use with the removable lug rims manufactured by Firestone and Cleveland (and different from the Kelsey lose lug).
And from that same reference it has:
In a letter to the Ford branches dated March 7, 1924, the following appeared:
Wheels and Rims
“The necessary changes have been made in the Kelsey wheel and rims also the Firestone and Cleveland rims so that with the exception of a few Kelsey wheels which are still to be shipped, we will have but one wheel and one rim for production, even though they are being shipped from three different sources. The felloe band on the Kelsey wheel has been changed so that it is exactly the same dimension as the Ford, Hayes, or Motor wheel and a car could be built with one wheel of each make. The rims have been changed to the “attached lug” type and a car could be built using one rim of each Hayes, Kelsey, Motor Wheel, and Firestone.
All that adds up to a very high probability that you have a Firestone produced felloe (wheel). It may have been manufactured in agreement with the March 7, 1924 letter to Branches shown above. If so it would have likely been produced in March 1924 or later either as original equipment or as a maintenance replacement.
But if the felloe has a "cup" around the valve stem hole as shown in the photo below, then it could have been one of the earlier Ford supplied wheels that were made by both Firestone as well as Cleveland. Those used a rim that had a lug around the valve stem that would fit into the "cup" that was around the valve stem hole on the felloe. Below is a photo of the cup around the valve stem. Does your felloe have that style or similar "cup" around the valve stem on the felloe?
Respectfully submitted,
Hap l9l5 cut off
