What have you done with your T in December
Posted: Tue Dec 01, 2020 8:56 pm
by NU2theT
Well ladies and gentlemen the last month of a year I'm sure we won't ever forget.
Got the new front spring and shackles together, waiting for the paint to dry on various parts and the spring clip bar. Will get in a few more miles on before setting up for winter and digging into band replacement.
Re: What have you done with your T in December
Posted: Wed Dec 02, 2020 1:06 am
by Aussie16
Went to the Christmas tree farm in the T pickup to pick up this years tree. Merry Christmas to everyone here at the forum.
Posted: Thu Dec 03, 2020 5:02 am
by Roffe
Beautiful car and photo Warwick.
Posted: Fri Dec 04, 2020 12:30 am
After several weeks of doing other things (cutting & splitting firewood, cleaning up storm damage, planting trees, etc.) today I got back to work on my mag ring.
Applying Kaptan insulating tape to copper ribbons. I put it on both sides. It's 1 mil, so the winding has 2 mils of insulation between layers.
Winding a coil. It took awhile to figure out how to tie a finished coil with wire so it won't unwind.
Four down, 28 to go.
Posted: Fri Dec 04, 2020 8:39 am
by Tim Rogers
So when can we start sending you our mag ring cores for rebuilding?
Posted: Fri Dec 04, 2020 8:59 am
by AndreFordT
Waiting for some parts this week so I rebuided a few coils.
Andre
Belgium
Posted: Fri Dec 04, 2020 9:09 am
by AndreFordT
Steve, fine to see you back on the coilring.
You can use a 3/8 wide tape to block the end of each coil.
Don't forget to insulate the side of the coils at the place you plie over the strip to make the connection part of each coil.
Good luck
Andre
Belgium
Posted: Fri Dec 04, 2020 11:34 am
I'll leave that to Andre and RV and others. I hardly ever finish anything as it is. I don't need to take on anything new. :D
Posted: Fri Dec 04, 2020 1:37 pm
by TWrenn
Stored them! :(
Posted: Sun Dec 06, 2020 6:26 pm
by Ken Lefeber
Celebrated Wilma's 94th birthday with a short ride to the recently opened Johnsonville Marketplace.
Posted: Sun Dec 06, 2020 9:55 pm
by jachady
Spent an evening chasing a sunset.
Posted: Mon Dec 07, 2020 7:14 am
by ABoer
This morning I put new pistons in a friends engine , and mount the coilring and flywheel.
Toon
Posted: Mon Dec 07, 2020 8:29 am
by ABoer
And the Magneto is working OK
Toon
Posted: Mon Dec 07, 2020 6:18 pm
by Corey Walker
I did the last bit of disassembly on my rear axle. I was putting it off because I didn’t have a sleeve puller but I made one.
Posted: Mon Dec 07, 2020 10:21 pm
by ryanf1023
I finally began cleaning up my field coil rings. The apparatus is a little crude, but it works just fine.
15 more to go.
Posted: Thu Dec 10, 2020 1:10 pm
by WayneJ
It was 50 degrees and sunny yesterday in Batavia, IL, so ....
I was able to give the T a little exercise. Started on the 2nd pull.
Posted: Thu Dec 10, 2020 4:38 pm
by henryford2
Started freehand lettering (with patina) the truck. Enjoy
Posted: Thu Dec 10, 2020 5:13 pm
by John Codman
Started on the job of adjusting the clutch screws. The floormat is out, as are the front floorboards. The transmission top cover is off and the left rear wheel is jacked up. I'm hoping that in the next couple of days I will pull the spark plugs, then I'll have a go at actually doing he adjustment. Tomorrow is a birthday party for an old friend who is moving a couple of hundred miles away, so probably no progress until Saturday.
Posted: Thu Dec 10, 2020 5:22 pm
by Henry K. Lee
Got to get the boat done! Oh.., it will be towed behind a 1927 RPU on a period correct trailer and 1926 Johnson outboard. It only weighs about 90 lbs, White Cypress.
Priorities Man!
Posted: Thu Dec 10, 2020 6:50 pm
by dmdeaton
Got my small tanks filled so I can rivet Saturday
Posted: Sat Dec 12, 2020 7:31 pm
by NU2theT
Priorities Man!
That is cool Hank, post some pictures of that Johnson. I acquired a 25 last year, these are pretty rare indeed.
Posted: Sat Dec 12, 2020 7:51 pm
by Henry K. Lee
Here you go Scott!
Johnson catalog 1926 cover.jpeg (103.11 KiB) Viewed 9317 times
Posted: Sat Dec 12, 2020 9:59 pm
by TonyB
Absolutely nothing☹️
I’ve been working on my new (to me) house. Sanded the floors, some new drywall and refurbished the kitchen cabinets.
New kitchen
New kitchen
New patio door and new floor
I hope to move all the stuff in the workshop after the house move and resume T work in February.
Posted: Sat Dec 12, 2020 10:46 pm
by Michael Peternell
Here you go Scott!
And a picture of the elves you have working in the shop. You are a busy sum bitch!
Posted: Sun Dec 13, 2020 9:52 am
by NU2theT
Hank that is outboard eye candy, I will stop procrastinating on mine and give it some shine. I also have the brass lower prop and tank needs the fresh paint and decals.
Thanks for posting the pictures and love those old adds.
Posted: Sun Dec 13, 2020 5:25 pm
by John Codman
Henry, I love those old wooden boats! Also modern replicas of them.
Posted: Sun Dec 13, 2020 9:15 pm
I haven't worked on any of mine, however, am installing a new top on a 1920 owned by a member of our club. The hardest part is done. The bows have been wooded and pads installed with alignment of the bows. The windbreaker and rear panel are installed. Next, when we have another warm day, will be the top itself. Here at this time of year, we can go from rain, fog, hail, wind or warm sunshine. Some days get into the 70's and 80's. In 46 years we have lived here we have only had about an inch of snow a few times, usually if it is cold, there might be a few snowflakes mixed with light rain. We got some autumn leaves, but the next day the wind came up and blew them all away. About 2 weeks ago the wind got so strong it split a large Oak so I also have a lot of wood to cut up and maybe enough firewood for several years! So I work on the T when my knees and back are not bothering me. I try to do a few hours work each day but vary it from day to day. Sometimes raking leaves. After it rains there will also be weeds to cut and in winter some trees to prune. Anyway, when the top is on, the T will be almost ready to go home.
Posted: Mon Dec 14, 2020 7:19 am
by Art Ebeling
I am making the best of a fourteen day Covid quarantine and installed the fenders and hood. I still have to paint the correct fender bolts and screw the hood former to the firewall. I have thirteen days left so I am stretching it out. Art
Posted: Mon Dec 14, 2020 10:12 am
by rnkugel
Got new E-brake linings on the speedster. Pulled the carb of the 15 Touring to discover that the float was set about an 1/8" to high. reset to 1/4". Also discovered there was no gasket between float bowl and carb body. Glad I had one. Carb reinstalled back on car. Now in the middle of rewiring the entire 15 Touring. Long winters hear in Wisconsin are a great time for some tinkering.
Posted: Mon Dec 14, 2020 5:34 pm
by John_Aldrich
In the "parts gathering" mode so a buddy of mine and I can build a Depot Hack.
Posted: Mon Dec 14, 2020 6:25 pm
by John Warren
Nice Boat and motor, Hank. You are a man of many talents. SUPER JOB. thanks for sharing jw
Posted: Wed Dec 16, 2020 9:22 pm
by MKossor
Busy working in Santa's Model T work shop; he knows who's been naughty (?) and Nice. Better be good for goodness sake!
Happy Holidays!
Posted: Wed Dec 16, 2020 10:14 pm
I had two days of city driving on promotion work for Haigh's chocolates. Yum. Second day out, the Holley H1 resumed it's leaking when I stopped the van outside a couple of the stores. Then it decided to behave itself for the rest of the day.
I might finally have to fit one of Stan's H1 rebuilt carbs that looks too good to get dirty. At the same time, I can fit another alloy manifold which has no welding repairs and fix an exhaust manifold leak.
Posted: Sun Dec 20, 2020 7:50 pm
by Angmar
Attended a Christmas "Covid" parade for the town. People could watch safely as the cars drove past their homes. Lots of fun but dang cold.
Posted: Sun Dec 20, 2020 8:53 pm
by NealW
When you have temperatures in the mid 50's in December, you take advantage of it! Our 15 runabout sits low enough with the top up that I can get it out of the garage with the top up with 2" to spare. Our 21 touring is a few inches taller and requires the top down before backing out, or it will be a bad day. When it is time for a quick spin, it's never much of a choice which one I take!
Posted: Sun Dec 20, 2020 9:16 pm
by Angmar
Fantastic car Neil and what a clean garage....
Posted: Sun Dec 20, 2020 10:55 pm
Redid 5 coils, 4 with new points 5th is waiting. When I sold the 1921 huckster all my working coils went with it. Just finished up regapping the vibrators on the 4, need to check now on the HCCT. Can't drive the 25 without them! Got a Craftsman tilting head band saw yesterday. Need to get carbon paper to start make patterns so I can rewood it. Don't want to cut the plans up.
Posted: Mon Dec 21, 2020 8:44 am
by Mark Nunn
I removed and disassembled my front axle and spindles. I boxed them up to send out for repair and bushings. I'm waiting until after the shipping companies get caught up before send them out. I have one inner bearing race that can spin in the hub. I'll need to address that when parts arrive.
Posted: Mon Dec 21, 2020 8:49 am
by dmdeaton
I spent all day yesterday trying to find these two items
I found them after giving up twice
Posted: Fri Dec 25, 2020 10:24 am
by varmint
2020 has been interesting, haven't had much time for the Model T. On the pickup had an engine wear out at 250k miles so rebuilt an engine and its transmission had a failed torque converter. So, got one from the junkyard, rebuilt it and installed at the same time as the engine. Wife's car had a flat tire and was returning from the tire store when the transmission on it gave out completely, coasting home. Back to the junkyard for a transmission. Lost two relatives this year, one to COVID. But we still have each other and our jobs. Overall, I enjoyed this challenging year and we finally got the floor welded to the body.
1926 Coupe floor weld
Posted: Fri Dec 25, 2020 11:20 am
by John Codman
I always enjoy reading this monthly post. I am constantly amazed at the talent that I see here. This is an amazing group. Merry Christmas to all!
Posted: Tue Dec 29, 2020 3:51 pm
by Dallas Landers
Finished up the 27 for a friend.
Moved the RPU into the new shop and started the RM brake install.
Discovered I dont need to fight wire or zip ties to change the brake peddle. The visegrips worked great.
