Removing Sediment Bulb
Posted: Thu Dec 03, 2020 3:56 pm
by BLB27
I want replace the sediment bulb from my 1927 couple, but I am concerned about damaging something when trying to get it free. I would appreciate any comments/suggestions.
Re: Removing Sediment Bulb
Posted: Thu Dec 03, 2020 4:07 pm
by jab35
Bruce; I use a small pipe wrench on the tank fitting and another small pipewrench/large channel lock on the bulb. I added some penetrating fluid (50-50 mix of acetone and auto transmission fluid) to my dry, empty tank and also to the outside threads several weeks prior. If you don't use the second pipe wrench on the tank fitting to resist the torque, you risk cracking the solder on the tank. Others may have better ideas, good luck, jb
Posted: Thu Dec 03, 2020 4:17 pm
by Humblej
I agree, use 2 wrenches, and this is one of those situations that the blue wrench should not be used.
Posted: Thu Dec 03, 2020 9:16 pm
by jiminbartow
If you use a pipe wrench you should put some sort of cushion between the teeth and the steel to prevent indentations from the teeth. Cloth or wood strips will work, 1/8” rubber strips work better. Jim Patrick
Posted: Thu Dec 03, 2020 11:05 pm
by ivaldes1
If you break the tank just take it to a radiator shop they'll fix it quick. Mine came to me complete with a big crack and gas leak probably from over tightening. My local radiator shop fixed it for $30.
BLB27 wrote: ↑Thu Dec 03, 2020 3:56 pm
Posted: Fri Dec 04, 2020 12:20 am
by TRDxB2
jab35 wrote: ↑Thu Dec 03, 2020 4:07 pm
agreed may want another person to hold the wrench from twisting
Posted: Fri Dec 04, 2020 11:55 am
by Altair
I can remember some years ago I bought one of those fuel assemblies from one of the vendors and it came with some test specs that said it was tested with 10lbs pressure using water. With normal gasoline pressure it leaked even when new. I had to devise an accessory shut off.
Posted: Fri Dec 04, 2020 11:14 pm
by jab35
To Frank: Sorry for thread drift, but do you have a pic or description of the 'J' bolt used to secure the overflow pipe to the body? Thanks, jb
Posted: Sat Dec 05, 2020 12:13 am
by TRDxB2
jab35 wrote: ↑Fri Dec 04, 2020 11:14 pm
Langs sells a tube with the bolt kit
https://www.modeltford.com/item/2921.aspx This is all I could find
- 26 tank.jpg (53.35 KiB) Viewed 2546 times
Posted: Sat Dec 05, 2020 8:37 am
by jab35
Thanks, Frank, I made a tube, just need to make the clamp. Best, jb
