Yesterday 12/12, Ignacio Valdes started a post entitled "Drilling Steel?". Ignacio eventually solved his problem of difficulty in drilling steel, apparently by purchase of what was obviously a very high quality set of "Milwaukee" drill bits. Within that same post, Stan Howe posted what i consider some very valuable information concerning a brand of drill bits (Norseman) that he said are the best he's ever owned! I thought that such information was worthy of a this separate post. First of all, the Norseman brand is U.S.A. made, and I would assume that the Milwaukee brand must be U.S.A. made as well, as Ignacio indicated a huge difference in the performance with those drill bits.
The reason I thought to repeat in a separate post the information developed by Ignacio and Stan Howe is very worthy of a separate post, plus a little bit that I might add that I feel is important and appropriate here:
First of all, I brought up the web site of the Norseman Company that Stan mentioned, and it contains some very good information that talks about probably one of the most important things I actually learned (and actually RETAINED) from high school shop class in the 1950's! Mr. Murray, was extremely emphatic when he taught us how to purchase good quality drill bits. He said words to the effect that if you look at the information stamped into the shank of a drill bit, to ignore markings that might appear like, coated, or premium, magnum, tungsten, carbide, etc, etc, and if there was not an "HS" or an "HSS" stamped on the drill,,,,,"DON'T BUY IT!) That stands for "HIGH SPEED STEEL", which is the most important thing about the quality of a drill bit. And what I particularly noted on the Norseman website was that they also stressed the importance of "high speed steel", and I was particularly gratified to note that some things haven't changed in sixty plus years since my high school machine shop days! Anyway, FWIW, and thanks Ignacio & Stan for bringing this up, .....harold
Drill Bit Quality
Topic author - Posts: 408
- First Name: Harold
- Last Name: Schwendeman
- MTFCA Number: 0
- MTFCA Number: 0
Re: Drill Bit Quality
Sorry about posting the above for a second time,.....I was interrupted from the forum by a "CRASH" in the kitchen, which turned out do be a dropped bottle of salad dressing, and which of course required my "assistance" in clean-up operations, and when I got back to this, I thought I had not posted it and so posted it again, and I know there's a way to delete it but of course, being almost "computer illiterate" I can't figure out how to do that. And I think I remember somebody saying that you have only so much time to do that, which I may have exceeded. Oh well,...whatever,.....sorry,.....harold
- First Name: Dennis
- Last Name: Seth
Harold,
I hope you were careful and didn't cut your tongue on broken glass as you cleaned up the spilled salad dressing.
- First Name: Gordon
- Last Name: Clayton
- * REQUIRED* Type and Year of Model Ts owned: 27 TT
- MTFCA Number: 49977
Thanks ! I learned something. I guess you're never too old.
- First Name: Stan
- Last Name: Howe
- MTFCA Number: 19133
This is the set I have. CN-TECH NITRIDE-CRYO---- https://www.ebay.com/itm/Norseman-29pc- ... SwImRYIgYd
$130 on ebay. I didn't buy mine there. Might be cheaper someplace else. I have no dog in this anywhere, barking or otherwise.
I just ordered a set of the 1-60 bits. I have 3 or 4 other sets, most of them get pretty dull pretty quick.
I would buy another set of the CN-Tech ones in a heart beat if anything happened to the set I have.
- Last Name: Aldrich
- * REQUIRED* Type and Year of Model Ts owned: 1915, 1923. 1927
Couldn't STAND IT!!2nighthawks wrote: ↑Sun Dec 13, 2020 10:11 pmYesterday 12/12, Ignacio Valdes started a post entitled "Drilling Steel?". Ignacio eventually solved his problem of difficulty in drilling steel, apparently by purchase of what was obviously a very high quality set of "Milwaukee" drill bits. Within that same post, Stan Howe posted what i consider some very valuable information concerning a brand of drill bits (Norseman) that he said are the best he's ever owned! I thought that such information was worthy of a this separate post. First of all, the Norseman brand is U.S.A. made, and I would assume that the Milwaukee brand must be U.S.A. made as well, as Ignacio indicated a huge difference in the performance with those drill bits.
Just bought a set.
John Aldrich
Typical Model T Addict
