John,
Welcome to the forum! It looks like this is your second posting.
Even when the Model T is set up properly the cars running the 30 x 3 or 30 x 3 1/2 inch clinchers have a very quick steering compared to modern cars (1928 and later Fords etc.)
And from Jem Bowkett's 2009 posting he states his late 1909 had a similar issue -- it would go past a point and would NOT self-center anymore but go full lock in that direction. It did NOT go over center -- but it did go full lock:
++++++++++++++++++ From the old Forum ++++++++++++
located at:
http://www.mtfca.com/discus/messages/80 ... 1238532286
By Jem Bowkett on Monday, March 30, 2009 - 11:53 am:
My 09 has cut-outs on the back of the axle which allow the steering arms to go very near to parallel to the axle. If you swing the wheel too far over, it goes beyond the point where self-centring operates and pulls the wheel round to full lock, but it is not actually 'over-centre' on the pitman arm - you can yank it back, but I've only experienced it at walking pace. This applies equally on both locks.
It is however scary, and it worries me that it could occur when hitting a pothole at speed and tip us up. I have been thinking of putting some sort of stop - look at a Model A (the modern one, not the 1903) and the nut that holds the stubaxle pivot pin in place is a special long one which is a steering arm stop, so even if you lose the draglink, it will never go beyond normal lock.
And he has additional comments at:
http://www.mtfca.com/discus/messages/80257/86608.html
And Jem also commented later that same year at:
http://www.mtfca.com/discus/messages/80257/114164.html
By Jem Bowkett on Thursday, November 12, 2009 - 12:29 pm:
... When you get near to full lock, the pressure against the wheel at that acute angle pushes the axle back (top mount wishbone of course) so the castor becomes negative and it wrenches round onto full lock. Takes a really hard pull to get it central again.
++++++++++++++++++ end paste from the old forum +++++++++++++
There are several things that could be contributing to that issue. Some of those you have already said are in good condition (the kingpins, tie rod ends and wheel bearings are in good condition, not sloppy). But you also should still check:
With the car stopped and the front wheels on the ground, turn the steering wheel. It is also good to have someone turning the wheel while a second person looks for lost movement (i.e. a drag link, a pitman arm etc. doesn't move unitl the steering wheel is turned a couple of inches.) How much movement in the steering wheel before the wheels start to turn? You don't have to turn the road wheels -- you just want to find out how much play is at the steering wheel. And since you said the problem was when the wheels are in t a tight turn -- check it again with the steering wheel turned close to full lock. How much back and forth movement in the steering wheel before the front wheels start to turn? Is it more than when the front wheels were pointed straight ahead? But I would recommend you have someone hold the front wheels still and have someone else turn the steering wheel to see how much slack / slop there is.
the drag link -- does it have slop
the pitman arm (is it lose on the shaft - i.e. does the shaft turn a little bit inside of the pitman arm casting?
Is the lower steering column bracket firmly attached?
are the 4 rivets holding the steering gear case together (1909-very early 1915 steering case -- the later steering case is a one piece) at the top of the steering column still rivetted tight (no movement)
is the steering gear case at the top of the steering column still rivetted tight to the column (2 rivets)
Is the steering column base at the firewall tight and the firewall supporting it properly
Is the front axle held properly in place (it should move up and down freely with the spring supporting the movement but not much side to side or forward or backwards.)
Are the U-bolts connecting the front spring to the front cross member holding the spring firmly to the front cross member
Are the spring shackles and bushings in good shape -- allowing free movement of the spint up and down but not lose. Note worn bushings in the spring perch or in the front spring can cause it to be lose.
Are the front axle spring perches firmly attached and on the correct side of the axle (they can be installed on the wrong side easily with the later below the axle spring perches (1919ish to 1927). And there have been cases with those later spring perches where one side was correctly installed but the other side was the same spring perch but installed on the wrong side of the axle. For the 1909-1919ish above the axle spring perches -- if the wishbone and the spring perches are both in good condition you cannot install the wishbone if the perches are on the wrong side. That is because the hole for the wishbone is larger at the back side and smaller at the front where the threaded portion enters. But if they are worn badly -- Yes even the above the axle spring perches can be installed wrong and the wishbone fitted.
++++++++++++++++++ another 2009 posting ++++++++++++++
[Ref:
By Erik Johnson on Thursday, November 12, 2009 - 02:27 pm:
The early style front perches or spring hangers (wishbone over axle) are designed to accept the wishbone prongs from only one direction. (The wishbone holes on the perches are slightly tapered and are flat on the front and countersunk at the rear to accept the wishbone prongs. Likewise, the wishbone prongs are slightly tapered.)
If you are able to insert the wishbone into the perch from the opposite (incorrect) direction, then the wishbone prongs and/or the holes in the perches are severely worn.
Erik Johnson
+++++++++++++++++end old posting ++++++++++++++++
Is the wishbone holding the axle firmly with approximately 5 1/2 degrees of positive caster? (That was explained in more detail by Norman above -- Thanks Norman). Originally a 1909 to 1919ish would have the above the axle wishbone but sometimes they are replaced with a below the axle wishbone and/or braces below the axle are added to the above the axle wishbone.
Is the ball on the end of the wishbone that fits into the engine pan have minimal play but still free for the wishbone to move as the front spring absorbs bumps etc.
How to check the front axle caster to make sure it is not set too low. More positive caster makes the car's steering more stable going forward but more unstable backing up. Never back up fast in a stock T as by design the wheels tend to go full left or right when backing up. That is because "IF" you have the correct 5 1/2 degrees positive caster on the front axle -- when you are going backwards it has the effect of being 5 1/2 degrees negative and the front wheels want to go hard left or right. In the USA we have shopping cars that have casters on the front. And if I move the cart reward, the front wheels on the cart will turn around. The posting at:
http://www.mtfca.com/discus/messages/29/40382.html shows the paragraph Norman referenced. It also has how to use a plumb bob and pencil to do the check instead of a square.
From the MTFCA safety check list located at:
Steering
• Steering wheel has minimal (less than 2”)
to no play ____
• Acceptable wear and minimal to no play in:
Radius rod (wish bone) to crankcase ____
Ball arm (pitman arm) to steering
gear connecting rod (drag link) ____
Steering gear connecting rod
(drag link) to yoke ball ____
Spindle bolts (king pins) ____
Spindle connecting rod (tie rod) bolts ____
• Cotter key (or lock washers, if holes not drilled)
installed in the following:
front axle perch (2 required) ____
Steering gear bracket to frame
(3 required) ____
Ball arm (pitman arm to steering
post (1 required) ____
(drag link) to yoke ball (2 required)
Steering gear connecting rod (drag link)
to steering gear ball (2 required) ____
• Spindle connecting rod (tie rod) to
spindles [2 (1 per spindle)] ____
• Spindle bolts (king pins) [2(1/spindle)] ____
• Spindle arms [2(1/spindle)] ____
• Front spring hangers (shackles)
[4 (2 per side)] ____
• Front spring to frame [2 or 4 required,
depending on year] ____
• Yoke ball (1 required) ____
• Safety-wire crankcase studs holding
radius rod ball cap ____ NOTE -- cotter keys will keep the nuts from backing off but the studs can back out with the nuts -- that is why it says "Safety-wire"
• Grease in steering gear case and steering
gear bracket (also check gear post and
pinion gears for wear) ____
• Check for play in steering gear
case to steering column
(check rivets/taper pins) ____
• Lock screw installed in quadrant
Respectfully submitted,
Hap l9l5 cut off
