Are you thinking about LED lights for your Model T?
Posted: Thu Dec 24, 2020 8:43 pm
by Bill Robinson
I just posted this video on YouTube about a "before & after" installation of LED's on my '27 Tudor.
Before installation, I focused and aimed the incandescent bulbs according to the Model T Ford manual. After installation of the LED's the only adjustment was aiming each of the lights to the outside slightly so that the edges of the road are lit. I will say that this video does not do justice to the actual lighting of the LED's- lighting is greater than the camera shows.
https://youtu.be/cRh0C0u-gzY
Re: Are you thinking about LED lights for your Model T?
Posted: Thu Dec 24, 2020 9:16 pm
by Angmar
Great comparison video. I have a mag only car that I diverted the headlamp/running circuit and ran 12 v neg ground to. I installed 12 v LED bulbs front and rear and wow what a difference. Thanks for posting.
Posted: Thu Dec 24, 2020 9:24 pm
by Tim Rogers
No, my original incandescent setup works great...
Posted: Thu Dec 24, 2020 10:30 pm
by Moxie26
Bill : I am aware of two types of LED headlight bulbs available to fit Model T negative ground systems. Which ever one is used, I found a video with installation info for a Model A Ford that will help with Model T Ford installation and focus adjustments.
https://www.youtube.com/watch?v=5nXfpvrlQW4.
I left comments below this video..... rain / wind in my area of New Jersey keeping car in garage, but focusing methods are very helpful no matter what LED headlight bulb you may choose. my decision
Posted: Fri Dec 25, 2020 9:27 pm
by Moxie26
Bill: Looking at
www.ledlights.com will see replacement led bulbs for the negative ground tail and stop light bulbs.... plus offerings for negative ground headlight bulbs.
Posted: Fri Dec 25, 2020 9:31 pm
by Moxie26
Mistake ******
www.ledlight.com .
Posted: Sat Dec 26, 2020 1:38 pm
by rnwilliams
Good job Bill. I have the same light bulbs in my 1927 fordor. They make a huge difference.
Posted: Sat Dec 26, 2020 1:45 pm
by TWrenn
Nope. Now that I put an alternator on the Fordor, the lights stay nice and bright, and the ammeter is a fuzz above "0" when they
are on. So why go to all the bother? For what, maybe one or two short runs at dusk or barely dark. Naahhhh.
Posted: Sat Dec 26, 2020 5:14 pm
by Jem
What's an alternator? Next thing I'll be hearing someone talking about replacing the crank handle with an electric motor! Fools! It'll never work.
Posted: Sun Dec 27, 2020 11:51 pm
by Pep C Strebeck
Bill Robinson wrote: ↑Thu Dec 24, 2020 8:43 pm
Would it be possible for you to list a bulb number and/or the source which you acquired them from?
Posted: Mon Dec 28, 2020 9:04 am
by Bill Robinson
I understand that there is a shortage of these bulbs presently. Mine were purchased from
http://www.snjparts.com/ the first week of December and I got the last 4 they had in stock at that time. Maybe all of the vendors have gotten new shipments.
Please notice that these are negative ground.
Posted: Mon Dec 28, 2020 12:00 pm
by R.V.Anderson
Nah. I use Light Emitting Acetylene, not Light Emitting Diodes.
