Show Me Your Chevy Disc Wheel Setup!
Posted: Sat Jan 02, 2021 3:48 pm
by Tim Rogers
Looking for ideas on how to mount 21 inch Chevy wheels for a speedster project...
disc wheel.jpg (7.36 KiB) Viewed 2857 times
Re: Show Me Your Chevy Disc Wheel Setup!
Posted: Sat Jan 02, 2021 4:02 pm
by David Mazza
Those di steel wheels look so cool. I do someday want to also do some disc wheels on my roadster. At the moment I’m making aluminum disc covers to jazz my car up a tad. Here are the templates to get an idea what I’m doing.
Posted: Sat Jan 02, 2021 4:04 pm
by david_dewey
Easy, put them on a Chevy!!
Couldn't resist--Happy New Years!
Posted: Sat Jan 02, 2021 5:12 pm
by Mark Gregush
I made the spacers for mounting mine. About 7/8-1" thick. Re drilled the holes in the Chevrolet wheels to match the Ford hubs and used the flange plates along with Ford hub bolts. I haven't trimmed off the front ones and rears ended up just right with brake drums attached. Took a while to come up with set of the correct Jaxon rims for them. The 1926/27 and 1928 are different and will not mix and match.
Posted: Sat Jan 02, 2021 8:11 pm
by Henry K. Lee
Still have a few of these sets left.
Ford 6 lug to Chevy 6 lug with offset. Email if interested, with or without hubs mounted.
Hank
Posted: Sat Jan 02, 2021 8:54 pm
by David Mazza
Hank, would those adapters properly support 31 chev wheel to model t hub? I know someone who needs this adaptation. Thanks in advance!
Posted: Sat Jan 02, 2021 9:13 pm
by Henry K. Lee
They work perfect! The offset allows you to use Rocky Mountain Brakes.
Hank
Posted: Sat Jan 02, 2021 9:38 pm
by Roz
I like them. Here they are on my speedster. I redrilled the disks to match the T hubs. The disks have a 3” hole through the center, so I made adapters that just slip on the hubs and have a shoulder to fit inside the disk center hole. The adapters are 3/4” thick 6061T6 aluminum. Easy lathe job. They run straight and true. Sorry, I don’t have any close up pictures.
Posted: Sat Jan 02, 2021 9:54 pm
by David Mazza
Like you read my mind Hank! I passed your contact along. A local friend, also in the group that includes someone named Chad you know. There’s are few of us!
Posted: Sun Jan 03, 2021 1:59 am
by Mark Gregush
RE the lip for the wheel to center on, I did that also. When the weather allows, I will take photos of them on my 1925 cutdown pickup.
