Babbitt
Tractordoc
Last Name: Barclay
* REQUIRED* Type and Year of Model Ts owned: 1920 coupe
Babbitt
Post by Tractordoc » Tue Jan 05, 2021 3:22 pm
I have access to a bunch of these bars of Babbitt, wondering if it is any good. Opinions?
Thanks George,
MTFCA Number: 14972
MTFCI Number: 15411
Re: Babbitt
Post by RajoRacer » Tue Jan 05, 2021 3:52 pm
I knew the manager at Non-Ferrous Metals in Seattle - I did a considerable amount of work on his father's Runabout.
MTFCA Number: 14972
MTFCI Number: 15411
Re: Babbitt
Post by RajoRacer » Tue Jan 05, 2021 3:53 pm
How did you come across those ?
Tractordoc
Last Name: Barclay
Re: Babbitt
Post by Tractordoc » Tue Jan 05, 2021 4:04 pm
A friend has them they were used for ballast in a wood sailboat.
MTFCA Number: 1219
Re: Babbitt
Post by Rich Eagle » Tue Jan 05, 2021 4:11 pm
George Hand
Last Name: Hand
* REQUIRED* Type and Year of Model Ts owned: 1912 open express, 1920 touring, 1926 tudor-lisenced and insured, 1921tt project 1922 fendered chassis, 192x tt dootle bug 192xengine w/winch projects
MTFCA Number: 28114
MTFCI Number: 21834
Re: Babbitt
Post by George Hand » Tue Jan 05, 2021 5:58 pm
If it was not satisfactory for Automotive use (Model T or A Ford), I am sure it would be useful for a Stationary or Hit-n-Miss Engine.
George
MTFCA Number: 14972
MTFCI Number: 15411
Re: Babbitt
Post by RajoRacer » Tue Jan 05, 2021 6:18 pm
Hopefully a couple of our "Babbitt pourers" will chime in but I believe Premium Nickel was acceptable for our engines.
John E. Guitar
Last Name: Guitar
Board Member Since: 2012
Re: Babbitt
Post by John E. Guitar » Tue Jan 05, 2021 7:04 pm
It conforms to ASTM B-23, Grade 2 which is ok for Model Ts.
http://nfmetals.com/babbitt-metal/
Tractordoc
Last Name: Barclay
Re: Babbitt
Post by Tractordoc » Tue Jan 05, 2021 10:13 pm
Thanks for the replies. Looks like like it might be good stuff, I'm sure my friend will be surprised. I was thinking about trying some in a hitmiss engine don't think I would trust my Babbitting skills on a T block, maybe someday.
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Board Member Since: 2014
Re: Babbitt
Post by Gene_French » Wed Jan 06, 2021 9:59 am
George:
i recommend N-F smelters ... the Nickle 2 babbitt is correct for our use and is designed for automotive high speed high pressure applications ...also N-F smelters will sell in small quantities that suit our small business or hobby situations ... good people to deal with ...always an optimist Gene French
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Re: Babbitt
Post by Adam » Wed Jan 06, 2021 12:59 pm
Just because an old ingot says anything on it does not mean that is what the ingot is...
Here you have some ingots that were used as ballast in a sailboat. It is quite possible that someone decades ago found an old mould that was the right size for what they wanted to do and then cast a bunch of ingots of whatever they could melt to use for ballast weight in a sailboat. Maybe not in just that one boat, but maybe in dozens or even hundreds of boats. Or, It could be bearing metal that could make satisfactory bearings. I wouldn’t ever take the chance of using any bearing metal I wasn’t 100% sure of.
Some bearing metal suppliers can assay a sample for you and tell you exactly what it is. That was a $100 service when I inquired with my supplier several years ago.
The scrapyard that takes all my unusable T stuff would pay $3/pound for babbitt a couple years ago. If you go to a major scrap buyer, they have a device that will tell them enough about those ingots that they can make an offer on them.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Babbitt
Post by Dan McEachern » Wed Jan 06, 2021 1:17 pm
George- if there is any concern regarding the authenticity of your bars, take one to a scrap metal dealer and ask them to shoot it with their XRF gun.
Most scrap yards have them and should be willing to check a bar as a favor or for a small gratuity. I would imagine that most metal suppliers guard their ingot molds pretty well but. . . . . Any way nice find. Dan
Tractordoc
Last Name: Barclay
Re: Babbitt
Post by Tractordoc » Wed Jan 06, 2021 10:34 pm
Not a bad idea, I know the manager of our local scrap yard pretty well might take a bar there and see what they say. Thanks again for the input. George
J1MGOLDEN
Last Name: Golden
MTFCA Number: 14294
MTFCI Number: 13562
Re: Babbitt
Post by J1MGOLDEN » Thu Jan 07, 2021 5:31 pm
The Babbitt formula had several options and included lead, but now new Babbitt is being advertised as lead free.
Henry Ford's official Babbitt was mostly tin and only 15 % lead.
J1MGOLDEN
Last Name: Golden
MTFCA Number: 14294
MTFCI Number: 13562
Re: Babbitt
Post by J1MGOLDEN » Thu Jan 07, 2021 5:39 pm
This is a change from the earlier 15 %.
MARCH 2, 1927 Letter GL1600 from the Fargo branch
(Found id Bruce McCalley's book)
For your information, the following is a comparative analysis of the babbitt in a connecting rod re-babbitted by an outside concern, and standard Ford babbitt:
Outside Standard Ford
Tin 82.96 % 85-86 %
Lead 5.00 % .10(max.) %
Copper 5.15 % 7.00-7.5 %
Antimony 6.89 % 7.00-7.50 %
The letter continues, stating that the increased copper in the Ford Babbitt gives greater wear, and stresses that the dealers should use the Ford Babbitt instead of any outside material.
Dan McEachern
First Name: DAN
Re: Babbitt
Post by Dan McEachern » Thu Jan 07, 2021 6:43 pm
True Nickel Babbitt has never had any lead in it. Most knowledgeable shops only use Nickel Babbitt in engine bearings. Its not lead free because its politically correct. Just FYI
Dennis Fleming
Last Name: Fleming
* REQUIRED* Type and Year of Model Ts owned: 1913 touring,23 TT Express,23 Center Door,15 Touring,22 Speedster,22Coupe
MTFCA Number: 27815
MTFCI Number: 19314
Re: Babbitt
Post by Dennis Fleming » Fri Jan 08, 2021 10:04 am
Are these useable for engine Babbitt ?
Dan McEachern
First Name: DAN
Re: Babbitt
Post by Dan McEachern » Fri Jan 08, 2021 7:36 pm
The two bottom ones- the XXXX Nickel ones are for sure- purchased my babbitt from them for years before they closed their plant in San Francisco.
Last Name: Hatch
MTFCA Number: 49974
Re: Babbitt
Post by Dan Hatch » Fri Jan 08, 2021 10:40 pm
Here is link to company that makes Ford Babbitt. Dan
https://stores.acrosales.com/fordbabbitt/
