Babbitt
Topic author - Posts: 22
- Last Name: Barclay
- * REQUIRED* Type and Year of Model Ts owned: 1920 coupe
Babbitt
I have access to a bunch of these bars of Babbitt, wondering if it is any good. Opinions?
Thanks George,
Thanks George,
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: Babbitt
I knew the manager at Non-Ferrous Metals in Seattle - I did a considerable amount of work on his father's Runabout.
Re: Babbitt
How did you come across those ?
Re: Babbitt
A friend has them they were used for ballast in a wood sailboat.
- MTFCA Number: 1219
Re: Babbitt
Perhaps you have seen this:
https://www.icollector.com/item.aspx?i=20352959
- Last Name: Hand
- * REQUIRED* Type and Year of Model Ts owned: 1912 open express, 1920 touring, 1926 tudor-lisenced and insured, 1921tt project 1922 fendered chassis, 192x tt dootle bug 192xengine w/winch projects
- MTFCA Number: 28114
- MTFCI Number: 21834
Re: Babbitt
If it was not satisfactory for Automotive use (Model T or A Ford), I am sure it would be useful for a Stationary or Hit-n-Miss Engine.
George
George
Re: Babbitt
Hopefully a couple of our "Babbitt pourers" will chime in but I believe Premium Nickel was acceptable for our engines.
- Last Name: Guitar
- Board Member Since: 2012
Re: Babbitt
Thanks for the replies. Looks like like it might be good stuff, I'm sure my friend will be surprised. I was thinking about trying some in a hitmiss engine don't think I would trust my Babbitting skills on a T block, maybe someday.
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
Re: Babbitt
George:
i recommend N-F smelters ... the Nickle 2 babbitt is correct for our use and is designed for automotive high speed high pressure applications ...also N-F smelters will sell in small quantities that suit our small business or hobby situations ... good people to deal with ...always an optimist Gene French
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Re: Babbitt
Just because an old ingot says anything on it does not mean that is what the ingot is...
Here you have some ingots that were used as ballast in a sailboat. It is quite possible that someone decades ago found an old mould that was the right size for what they wanted to do and then cast a bunch of ingots of whatever they could melt to use for ballast weight in a sailboat. Maybe not in just that one boat, but maybe in dozens or even hundreds of boats. Or, It could be bearing metal that could make satisfactory bearings. I wouldn’t ever take the chance of using any bearing metal I wasn’t 100% sure of.
Some bearing metal suppliers can assay a sample for you and tell you exactly what it is. That was a $100 service when I inquired with my supplier several years ago.
The scrapyard that takes all my unusable T stuff would pay $3/pound for babbitt a couple years ago. If you go to a major scrap buyer, they have a device that will tell them enough about those ingots that they can make an offer on them.
- First Name: DAN
- Last Name: MCEACHERN
Re: Babbitt
George- if there is any concern regarding the authenticity of your bars, take one to a scrap metal dealer and ask them to shoot it with their XRF gun.
Most scrap yards have them and should be willing to check a bar as a favor or for a small gratuity. I would imagine that most metal suppliers guard their ingot molds pretty well but. . . . . Any way nice find. Dan
Re: Babbitt
Not a bad idea, I know the manager of our local scrap yard pretty well might take a bar there and see what they say. Thanks again for the input. George
- Last Name: Golden
- MTFCA Number: 14294
- MTFCI Number: 13562
Re: Babbitt
The Babbitt formula had several options and included lead, but now new Babbitt is being advertised as lead free.
Henry Ford's official Babbitt was mostly tin and only 15 % lead.
- Last Name: Golden
Re: Babbitt
This is a change from the earlier 15 %.
MARCH 2, 1927 Letter GL1600 from the Fargo branch
(Found id Bruce McCalley's book)
For your information, the following is a comparative analysis of the babbitt in a connecting rod re-babbitted by an outside concern, and standard Ford babbitt:
Outside Standard Ford
Tin 82.96 % 85-86 %
Lead 5.00 % .10(max.) %
Copper 5.15 % 7.00-7.5 %
Antimony 6.89 % 7.00-7.50 %
The letter continues, stating that the increased copper in the Ford Babbitt gives greater wear, and stresses that the dealers should use the Ford Babbitt instead of any outside material.
Tin 82.96 % 85-86 %
- First Name: DAN
Re: Babbitt
True Nickel Babbitt has never had any lead in it. Most knowledgeable shops only use Nickel Babbitt in engine bearings. Its not lead free because its politically correct. Just FYI
- First Name: Dennis
- Last Name: Fleming
- * REQUIRED* Type and Year of Model Ts owned: 1913 touring,23 TT Express,23 Center Door,15 Touring,22 Speedster,22Coupe
- MTFCA Number: 27815
- MTFCI Number: 19314
Re: Babbitt
Are these useable for engine Babbitt ?
- First Name: DAN
Re: Babbitt
The two bottom ones- the XXXX Nickel ones are for sure- purchased my babbitt from them for years before they closed their plant in San Francisco.
- Last Name: Hatch
- MTFCA Number: 49974
Re: Babbitt
Here is link to company that makes Ford Babbitt. Dan
https://stores.acrosales.com/fordbabbitt/
