Chickasha almost ready
D.Yoder
First Name: DEAN
Last Name: YODER
* REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
MTFCA Number: 295
MTFCI Number: 127
Post by D.Yoder » Sat Mar 02, 2019 5:49 pm
Heater installed almost ready to head south.
:D
Rob
First Name: Rob
Last Name: Heyen
Re: Chickasha almost ready
Post by Rob » Sat Mar 02, 2019 6:12 pm
Brrrrrrrr......
John Warren
Last Name: Warren
Post by John Warren » Sat Mar 02, 2019 6:30 pm
That's a cute little stove. Is it something that you put together? What does it use for fuel? Looks like you could cook on it too. Thanks
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
Board Member Since: 2008
Post by FreighTer Jim » Sat Mar 02, 2019 9:12 pm
Like Dean - the stove runs on “ True Grit “ ..... :idea:
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
MWalker
Last Name: Walker
MTFCA Number: 314
Post by MWalker » Sat Mar 02, 2019 9:37 pm
Dean -- The weather here (just east of Chickasha) will be cold this next week, but in the 60's by the weekend. Chances are it will be OK by the time the swap meet rolls around.
Jim Derocher
First Name: Jim
Last Name: Derocher
* REQUIRED* Type and Year of Model Ts owned: 1919 Station Wagon
Post by Jim Derocher » Sat Mar 02, 2019 9:45 pm
That stove looks a lot like one my neighbor had in his garage. The one he had used wood and was used in a caboose for heat and warming chow. Looks great! JD
Tim Rogers
Last Name: Rogers
Post by Tim Rogers » Sun Mar 03, 2019 7:19 am
Very awesome, but please have a CO2 detector onboard.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sun Mar 03, 2019 11:44 am
...have a CO2 detector onboard.
I believe that would be CO (carbon monoxide).
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Sun Mar 03, 2019 4:52 pm
That's really neat! Looks right at home!
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Sun Mar 03, 2019 6:05 pm
Maybe a CO2 detector to make sure you're still alive.
1924 Touring
FreighTer Jim
Last Name: Jarzabek
MTFCA Number: 29562
MTFCI Number: 24398
Post by FreighTer Jim » Sun Mar 03, 2019 9:20 pm
I have had a loft at the front of my last (2) enclosed trailers.
Sometimes I have had to sleep up there in sub zero temperatures.
Rather than heat the surrounding area - I layer sleeping bags over me
and take a large sturdy plastic tote & turn it on it’s side - put my pillow
in it and then drape a blanket over it.
With some adjustment you have the perfect blend of fresh air and ventilation
to exchange the carbon dioxide you breathe out with the air you breathe in.
Your body is a great little furnace that generates sufficient heat to provide
adequate warmth to keep you quite comfortable if you insulate it correctly.
Headaches you may get while sleeping in the cold are usually caused by
inhaling the carbon dioxide you exhale out during respiration.
FJ
