Building a Foot Throttle from Scratch
Topic author - Posts: 5339
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
A little time is all it takes with minimal supplies. My Dad and I came up with this system years back, you can even make up a chain and bell crank to still use a hand throttle in conjunction with it.
Simple list of materials from your local hardware stores; 2 feet 1/8" X 1" flat steel (cut in half) , 2 each 3/8" ID steel tubing 1 1/8" long, 13" X 5/16" round stock, 2 each 3/8" OD steel fuel tubing 1 1/2" long, 1 each old spoon gas pedal (1930's Fords, etc.) 3 each 1/8" tension/split pins 3/4" long, 1 each 12" X 3/16" round stock, some light tension pull springs. I like using self sealing washers under the mounting plate to the transmission inspection plate. Really stops any leaks. The fuel tubing is installed into the heavier tubing to act as a secondary bushing and helps in any misalignment issues and you simply just flare the ends. You will also need two ends for the hook up at carb and pedal rod, the pedal rod downward arm can be purchased from multiple vendors.
All the Best,
Hank in Tin-A-See
All the Best,
Hank in Tin-A-See
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
- First Name: Randall
- Last Name: Strickland
Re: Building a Foot Throttle from Scratch
made mine simple
- Attachments
- cap grinder,foot throtle 004.JPG (47.86 KiB) Viewed 4329 times
- cap grinder,foot throtle 009.JPG (59.89 KiB) Viewed 4329 times
- First Name: Joe
- Last Name: Kowalczyk
- MTFCA Number: 49558
Nice job Hank, nice simple approach and thnx for the components list, I'm sure if anyone plans on building one, your list and pictures will save time.
Joe
Joe
Regards,
- First Name: Thomas
- Last Name: Hicks
- * REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
- MTFCA Number: 32518
Thanks for sharing. My TT needs one and I think I can build it by following your plans.
This is one time when our correct hand drive cars makes the task easy. Pedal on the right, straight rod for ward to the carb just like Hank shows. Somebody here in Australia made a bolt on fitting which allows the foot throttle to over-ride the hand throttle but leaves it still connected and opperable if required.
- First Name: Paul
- Last Name: Ayres
- MTFCA Number: 49475
- MTFCI Number: 24545
I have an old TTP foot throttle or parts thereof. Does anyone have the installation instructions or diagram for it? It has a bellcrank, but it is not obvious how it is installed. Paul
- First Name: Vernon
- Last Name: Worley
- MTFCA Number: 49462
Kewl idea and looks authentic.
This is not rough on the spring return and no additional one needed?
Vern (Vieux Carre)
