Building a Foot Throttle from Scratch
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sun Mar 03, 2019 2:31 pm
A little time is all it takes with minimal supplies. My Dad and I came up with this system years back, you can even make up a chain and bell crank to still use a hand throttle in conjunction with it.
Simple list of materials from your local hardware stores; 2 feet 1/8" X 1" flat steel (cut in half) , 2 each 3/8" ID steel tubing 1 1/8" long, 13" X 5/16" round stock, 2 each 3/8" OD steel fuel tubing 1 1/2" long, 1 each old spoon gas pedal (1930's Fords, etc.) 3 each 1/8" tension/split pins 3/4" long, 1 each 12" X 3/16" round stock, some light tension pull springs. I like using self sealing washers under the mounting plate to the transmission inspection plate. Really stops any leaks. The fuel tubing is installed into the heavier tubing to act as a secondary bushing and helps in any misalignment issues and you simply just flare the ends. You will also need two ends for the hook up at carb and pedal rod, the pedal rod downward arm can be purchased from multiple vendors.
All the Best,
Hank in Tin-A-See
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: Building a Foot Throttle from Scratch
Post by Henry K. Lee » Sun Mar 03, 2019 2:37 pm
More Photos!
Randall strickland
First Name: Randall
Last Name: Strickland
Post by Randall strickland » Sun Mar 03, 2019 7:46 pm
made mine simple
cap grinder,foot throtle 004.JPG (47.86 KiB) Viewed 4346 times
cap grinder,foot throtle 009.JPG (59.89 KiB) Viewed 4346 times
havnfun
First Name: Joe
Last Name: Kowalczyk
MTFCA Number: 49558
Post by havnfun » Sun Mar 03, 2019 9:59 pm
Nice job Hank, nice simple approach and thnx for the components list, I'm sure if anyone plans on building one, your list and pictures will save time.
Joe
Regards,
Tom Hicks
First Name: Thomas
Last Name: Hicks
* REQUIRED* Type and Year of Model Ts owned: '24 TT, '26 TT, '24 Speedster, '26 Speedster
MTFCA Number: 32518
Post by Tom Hicks » Sun Mar 03, 2019 10:08 pm
Thanks for sharing. My TT needs one and I think I can build it by following your plans.
Post by Allan » Sun Mar 03, 2019 11:18 pm
This is one time when our correct hand drive cars makes the task easy. Pedal on the right, straight rod for ward to the carb just like Hank shows. Somebody here in Australia made a bolt on fitting which allows the foot throttle to over-ride the hand throttle but leaves it still connected and opperable if required.
PEAyres
First Name: Paul
Last Name: Ayres
MTFCA Number: 49475
MTFCI Number: 24545
Post by PEAyres » Mon Mar 04, 2019 3:10 pm
I have an old TTP foot throttle or parts thereof. Does anyone have the installation instructions or diagram for it? It has a bellcrank, but it is not obvious how it is installed. Paul
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Post by varmint » Mon Mar 04, 2019 6:58 pm
Kewl idea and looks authentic.
This is not rough on the spring return and no additional one needed?
Vern (Vieux Carre)
