Bosch DU4 Newbie
Posted: Wed Jan 20, 2021 9:36 am
by Tim Rogers
I will be using this Bosch DU4 on my project but noticed this lose wire on the bottom- what should be done with it?
Re: Bosch DU4 Newbie
Posted: Wed Jan 20, 2021 12:02 pm
by Thorlick
Tim,
I believe that gets fastened by a screw inserted into the hole beneath the wire.
- Bosch DU4
TH
Posted: Wed Jan 20, 2021 12:15 pm
by Dropacent
That is correct. I’d use a star washer there also. Make sure the carbon button is still under the piece of spring steel. If it’s an untouched unit, it’s good advice to take the thing apart and clean the old dried lubricant from the ball bearings, and use fresh oil when reassembled.
