The Modern Ford Heater-Old Advertising
Topic author - Posts: 1523
- First Name: Herb
- Last Name: Iffrig
- First Name: Steven
- Last Name: Sebaugh
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
- MTFCA Number: 49646
Re: The Modern Ford Heater-Old Advertising
Yes, I actually have one that I got off Ebay about four years ago.
1924 Model T Touring
1924 Model TT Truck
1930 Model A Pheaton
1924 Model TT Truck
- First Name: Craig
- Last Name: Vechorik
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1922 coupe
- MTFCA Number: 32602
Herb
I have that exact heater on my 1922 coupe. It works very well.... Almost too well! It will cook you in 40- 50 degree weather. I the summer, the "valve" won't cut the flow of hot air off, so I made a cap on the lathe to plug the end in the passenger compartment, to keep from being roasted. That helped a lot.
A word to the wise. If you find and install any sort of manifold heater, buy yourself battery powered portable a carbon monoxide meter. If you have a manifold leak, you will poison yourself at a stop light. Not so much when you are moving. The CO level will climb real fast iding at a stop light if you have any sort of leak.
"If a fly can, a flywheel"
If you have a closed car it is always best to have a window cracked when driving, regardless if you have a heater. They are prone to get exhaust and or blow by into the cab.
- MTFCA Number: 14972
- MTFCI Number: 15411
Mine doesn't Norm !
- First Name: Herb
- Last Name: Iffrig
Thank you for the comments.
